Clutch Bell help!
masense
Clutch Bell help! - 03.11.2009, 02:16 AM
i have TEKNO RC rc8
1512 3D
6s
20/44T
i want more pinion T.
22-24
clutchbell of REVO is to 20T.
Can you use Traxxas 24T Clutch Bell[TRA4124] as Clutch Bell of REVO?
http://www.amainhobbies.com/product_...ducts_id/14879
http://www.amainhobbies.com/product_...ducts_id/17710
marzac2
marzac2's Avatar
03.11.2009, 02:33 AM
If you have the 2-shoe clutch adapter, you are fine using those clutch bells in the links you provided. The 2 shoe adapter looks like this HERE:
If you have the 3 shoe clutch adapter, than you need larger 1/8th scale clutch bells like ones that came with the RC8 kit originally. The 3 shoe adapter looks like this HERE:
Losi 8 Buggy + Truggy & Associated SC8
Tekno RC Conversion Kits on all
MMM, MGM, Xcelorin ESC's
Tekno Neu "square can" brushless motors
Polyquest - Neu - Flight Power LiPo's
masense
03.11.2009, 02:59 AM
i have the 2-shoe clutch adapter.
clutch BELL of jato is the same as clutch BELL of REVO.
I purchase 2 clutch bell.
thank you!!
MetalMan
MetalMan's Avatar
03.11.2009, 03:10 AM
Actually, Jato clutch bells are mod0.8 (32pitch), while Revo clutch bells are mod1. This means Jato gears won't mesh with your RC8, which uses mod1 gears.
Those clutch bells you linked won't work with the RC8.
marzac2
marzac2's Avatar
03.11.2009, 09:40 AM
Thanks Metal Man.
I missed that one. I am not super familiar with Traxxas products.
Mod 1 pitch is much different than 32 pitch (MOD 0.8).
I don't know anybody with gears that large for the 2 shoe clutch. You might look for a smaller spur gear.
Matthew_Armeni
Matthew_Armeni's Avatar
03.11.2009, 01:43 PM
If you plan on gearing that high then I don't think you'll be able to find a clutch bell with that many teeth nor would I recommend using it if you did find one. You might be able to have a custom one done by Mike or RRP but that's not cheap and again, for a clutch, that's just too tall of a ratio.
I'd recomend going with one of Mike's pinions, like these. They go all the way up to 25T. I'm assuming your doing speed runs because a 1700kv motor on 6s is already fast geared normally, you're proposed setup is, well, a speed run setup.
  Send a message via AIM to Matthew_Armeni
masense
03.11.2009, 03:33 AM
Please teach me.
I look for 22T 24T in mod1 cluth bell of the REVO size.
drkros3
03.11.2009, 03:40 AM
whats the reason for gearing it so high???
masense
03.11.2009, 03:58 AM
more speed^^
Because it is MGM16024, I am possible for 8s.
However, I am too heavy in RC8.
It is a wise policy to put up a thing of a pinion.
masense
03.11.2009, 08:29 PM
thank you...
yes 44/20T very fast.
i want 22-24T
tekno Long Shank Pinion to 17T.
The pinion of MIKE is short.
i look for a smaller spur gear.
Will you teach SPUR of 42T / 40T which is usable in rc8?
