Opening Medusa
Jabe
Opening Medusa - 02.28.2009, 09:06 AM
So id like to open up my medusa, to clean it from inside, is that rear endplate glued?
How it should be opened, that i wouldnt damage windings?
Its Afterburner V2 80mm, if that makes any difference.
Medusa
transtalon
Medusa - 02.28.2009, 09:56 AM
I wouldn' open it. I would simply blow it with some high pressure compressed air. This is much safer and easier.
RUSTED
02.28.2009, 02:35 PM
yes , i think its glued . coz the rear endplate on mine used to pop out everytime i drive my car till i got the rcm motor clamp, so i woudnt open it u m8 damage somethn i suggest doing wat transtalonn said
Jabe
02.28.2009, 04:06 PM
Well how about, when you need to change those bearings?
Im using RCM heatsink with clamp, so it wont get loose when driving.
02.28.2009, 11:27 PM
Tap the shaft on a solid object, like a solid block of wood. Make sure the motor is perpendiculat to the solid object. I slightly bent the rear plate when popping it off, so be careful.
