Single Speed Conversion
6606j
Single Speed Conversion - 03.26.2006, 03:22 AM
This question is for any one who might be able to give me an answer. can the single speed conversion be used for first gear instead of second? Before i get flamed i should tell you that I'm turning my emaxx into a crawler but need to shed weight.
Serum
Serum's Avatar
03.26.2006, 04:11 AM
No, it is not possible, the distance between the idler /input gear/output gear needs to be different.
maxxdude1234
maxxdude1234's Avatar
03.26.2006, 04:33 AM
Plus on the input shaft 2nd gear is closest to the spur gear, 1st gear is farthest away.
Serum
Serum's Avatar
03.26.2006, 04:58 AM
that can be fixed easily.
6606j
03.26.2006, 04:07 PM
can't the gears be slid to the positions on the shaft to the second gear spot?
coolhandcountry
coolhandcountry's Avatar
03.26.2006, 04:10 PM
Your idler shaft will be in the wrong spot. Could you drop your spur and pinion gears low enough to do the same ratio?
6606j
03.26.2006, 07:52 PM
I'm just wondering about the gear ratio in the transmission because I know I can lower with the spur and pinion but wouldn't that be counter active to using the high gear in the tranny, I was just wondering how low you can gear on the spur and pinion, how tall a spur and how small a pinion can you get?
I 've been thinking about it, and I think I might keep both gears after all just in case in some crawling situations where you need more wheel speed and less torque
Torque won't be a problem, because I plan on using twin 65 T Lathe motors run off of the stock EVX but rewired for 7.2 Volts, instead of the 14.4v
