clutch or pinion
clutch or pinion
brian2njoy
clutch or pinion -
03.30.2009, 09:49 AM
I have the mmm conversion but the 5 mm pinion that came with it does not line up with the spur gear its like the spur gear teeth are bigger than the pinion teeth nay help or just run a clutch thanks
brian2njoy
2
03.30.2009, 09:53 AM
The MMM comes with an 18T 32p pinion - you need a mod1 pinion.
Check mikes store
http://rc-monster.com/proddetail.php?prod=5mmmod1pinion
Find all posts by Arct1k
3
brian2njoy
03.30.2009, 09:54 AM
thanks
brian2njoy
4
03.30.2009, 09:56 AM
No problem... Use this tool to work out your pinion size - Gear for 40PMH
http://scriptasylum.com/rc_speed/
Hybrid Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
