Info on neu motors with a gearbox -
04.06.2009, 11:18 PM
So I purchased a neu 1515 2d with a gearbox. I got a smoking deal, and also always wondered about the gearbox construction, etc.
Got the motor in today, and i can say that the gearbox is very nicely made. Took it off the motor, and found that the pinion attached to the motor shaft looks to be a 32p 8t pinion (looks like a clod pinion). The shaft coming out of the motor is less than 1.2 inch long, and the pinion looks to be bonded on.
So not much use for a car, unless I plan to use a 6mm bore pinion, which will fit over the pinion and could clamp to the existing pinions hub, which is exactly 6mm.
I plan to contact neu and see what they would charge me to swap a std car rotor in...
Any ideas who to contact about this?
I will take some pics tomorrow and post em up!
