Are the Stock E Revo and Slayer diffs the same?
sikeston34m
sikeston34m's Avatar
Are the Stock E Revo and Slayer diffs the same? - 08.27.2009, 09:55 PM
Like the Title says:
Are they the same?
nitrostarter
nitrostarter's Avatar
08.27.2009, 10:03 PM
Erevo has part number 5382X and 3978 in the center to hold the spider gears more secure while the Slayer spiders are a simple pin setup.
Here are pics:
REVO
SLAYER
N. Rustler conversion
sikeston34m
08.27.2009, 10:21 PM
VERY Good eye for detail! Thank you.
My first set of Stock E Revo diffs lasted 50 or 60 packs at least. Life wasn't easy on them either.
A Tooth broke off the rear pinion and the gears began chewing the floating particles up.
I wonder if the Slayer Diff would be relatively as tough?
Hmmm..... Different cup too
nitrostarter
08.27.2009, 10:38 PM
Well they added the I-bar to the newer E-Revo's to beef them up to handle the BL power better. Adding the I-bar thus changed the design of the cup.
The Slayer diffs are slightly weaker in design but will hold their own to some mild to strong BL setups.
