Stock Slash on 3s
lucias
lucias's Avatar
Stock Slash on 3s - 04.08.2009, 09:49 AM
Do you think I will fry the stock speed controller in a slash running it on 3s?
Foxracin
04.08.2009, 10:03 AM
Yes.
04.08.2009, 10:13 AM
I ran 3s on the XL-5/Titan 550 12T for a little while in my 4tec conversion just to see if it worked. It armed and ran fine, but I expected to see smoke. It runs, just not sure how long. And the BEC, being linear, will heat up quite a bit more with 3s than 2s.
rootar
rootar's Avatar
04.08.2009, 11:02 AM
the titan actually runs pretty damn good on 3s with a mm or sidewinder.
junkman
04.08.2009, 11:28 AM
take it for what its worth, but I ran one for 8 packs or so on 3s, otherwise completely stock truck. No damage, just finally put the brushless stuff in it. Def wakes it up!
lucias
lucias's Avatar
04.08.2009, 11:42 AM
Mine worked it didn't go up in smoke.. I wondered if I put a fan on it if it would help.. I think they are going to try and keep the Slash class stock so I didn't want to half to swap things back and forth between a race and when I want to bash with it..
rawfuls
roofles.
rawfuls's Avatar
04.08.2009, 05:38 PM
How about if I run the XL5 with a 2S 5000mAh pack?
I tried it for a few bursts.
And the yellow (non-waterproof) was starting to heat up, but nothing dramatic.
Tower says you really shouldn't because of it's intakes, and whatnot. (Current wise)
