1/12th Jammin CRT.5 Brushless Build-up
AJrc
1/12th Jammin CRT.5 Brushless Build-up - 03.10.2009, 06:07 PM
Well, im kinda new here. I made a Jammin X1 CRT brushless, so I thought i should do a crt.5. Here it is, it has the rc-bros conversion kit. Here are the things I am going to get for it. I need help with battery decision.
Thanks
Feigao 9l- (on the way-thanks bustitup)
Mamba Max Esc-
Battery-??
AJrc
03.10.2009, 06:08 PM
I installed the spektrum servo and spektrum receiver. Here are pics.
dmeylman
04.17.2009, 08:54 PM
where can i buy conversion kit like that???
dmeylman
04.19.2009, 05:22 PM
[QUOTE=AJrc;268719]I installed the spektrum servo and spektrum receiver. Here are pics.
AJrc, where can I get the exact conversion like yours??? Thanks...
03.10.2009, 07:21 PM
First, decide on 3 or 4s. I have 2 crt.5....one is run on 2s which is my daughter's. The other is mine which I run on 3s and it screams! Mike sells some nice batts here of all shapes and sizes.
rootar
rootar's Avatar
03.10.2009, 08:33 PM
youll want a 3s with the 9L, something in the 2500-5000 range, the lower the mah the higher C rating youll need ill be using a 9L and 3s 3200 flightpower 30c pack, mike has plenty of 3s lipos to choose from from 2500-5000mah but you might want to wait a couple weeks if you can until he gets his new shipment of lipos in and youll have a MUCH larger selection....
AJrc
03.13.2009, 12:25 PM
Will the mamba max work with this motor and a 3s battery?
bruce750i
bruce750i's Avatar
03.13.2009, 12:31 PM
oh yeah
rootar
rootar's Avatar
03.13.2009, 02:46 PM
just need a external bec for the mm and its perfect.
03.13.2009, 10:27 PM
You don't need a ext bec for 3s, unless you want one
Always Dreamin
04.09.2009, 10:24 PM
looks good so far! I'd love to do a .5 conversion. They look like they pack a big package for their size.
Don't you run that setup on your Rustler? With the internal BEC, or no?
rootar
rootar's Avatar
03.13.2009, 11:13 PM
you do unless you want slow servos and high temps.... havent you seen the test of the internal bec output on the mm on 3s, it wont even handle a decent servo and the temperatures are considerbly higher.....
03.13.2009, 11:16 PM
Ok.... you convinced me.
tkhoo
04.06.2009, 10:25 AM
Hi, if I using MM+Feigao 9L on 3S and I supply my rx and servo with another pack of 6v battery, do I need ext BEC on 3S?Please advise. Thanks.
04.06.2009, 10:33 AM
If you use an external 6v battery pack this is doing the same job as a bec (so no external bex required)...
Remember to remove the red wire from MM to RX though if using a battery pack or bec.
