Charge adapter for everything
TexasSP
Something, anything, nothing
TexasSP's Avatar
Charge adapter for everything - 05.27.2009, 05:47 PM
https://www.ssl-stormerhobbies.com/c...1&showbig=6809
Just thought I would point this out. I may buy one just to have because you never know now do you.
www.cubicle101.com
kulangflow
Never Fast Enough
kulangflow's Avatar
05.27.2009, 05:58 PM
That could come in handy. I'd like to see the junction under the boot.
While they do provide the bare leads, it's interesting that they didn't include PowerPoles, my connector of choice. I thought they were pretty popular.
TexasSP
TexasSP's Avatar
05.27.2009, 06:05 PM
Didn't even catch the PP deal, I switched from deans to TRX connectors a while back because I like them better. I had considered the PP's though.
www.cubicle101.com
kulangflow
Never Fast Enough
kulangflow's Avatar
05.27.2009, 06:09 PM
I love the PP's because I never need Y-adapters to run different packs in series. :-)
Plus, for me, they're the easiest to solder and cheap to buy in bulk.
Andrew32
05.27.2009, 06:12 PM
saw it at the lhs a few days ago...although the numbers are different...
13.95 vs 32.99
and there are bare leads for your power poles
05.27.2009, 08:41 PM
I have seen these before as well...a friend has one and he loves it
Unsullied_Spy
Unsullied_Spy's Avatar
05.28.2009, 12:03 AM
A friend of mine has a Racer's Edge charger that has that integrated into it. I wouldn't mind having something like that for my Hyperion though. Thanks for sharing!
05.28.2009, 12:30 AM
Hey Brian, how good are the power poles? I have always wondered if they can keep up with the current demands like deans can?
Unsullied_Spy
05.28.2009, 12:43 AM
Those PPs are comparable to Deans, but they make PPs MUCH larger. I've seen them over 100 amps and I'm sure you can get bigger. The military uses those on aircraft, tanks, etc. so they can't be too bad (military stuff is more cheap than good, but...)
TexasSP
TexasSP's Avatar
05.28.2009, 12:48 AM
I can't say I would back that in my experience. The products I have been a part of manufacturing in the past to mil-spec standards were some of the best we made hands down. Mil-spec has very tough requirements that far exceed what most end users require by a long shot.
www.cubicle101.com
Unsullied_Spy
05.28.2009, 12:58 AM
True, but the lowest bidder usually gets the contract
Finnster
KillaHurtz
Finnster's Avatar
05.28.2009, 05:59 PM
We have a elec pallet jack @ work that has some powerpoles that are the size of a deck of cards each. They are rated for several hundred amps and work well enough. Don't know if you want those on your car tho
05.28.2009, 06:37 PM
I have the multi- charge adapter and love it.
Big power poles are often found at the robot places.....
kulangflow
Never Fast Enough
kulangflow's Avatar
05.29.2009, 03:02 AM
I love them. I've been using them for a few years now in all of my larger brushless vehicles. I've never seen one get hot even on 6s/2200kV monster applications.
Big fan I am. Here is where I buy them in bulk. I've always used 30A, but from now on I'll be using 45A, which has a bigger metal contact, but still fits in the same plastic housing.
alangsam
05.28.2009, 05:53 PM
i have two of these. they are great.
now we need balancer boards that have the top three banace connectors on one board
Hyperion
Align EX
Polyquest XH
