Rhino 5s1p 4900mAh 20C Lipo Problem
Mentat
Brushless Mentat
Mentat's Avatar
Rhino 5s1p 4900mAh 20C Lipo Problem - 06.24.2009, 03:37 PM
HI guy, got to take my 8ight-t to the track yesterday for the first time and loved it. I have 2 batteries a Turnigy 5000mAh 25C 4s1p ZERO issues so far. Then there is the Rhino 5s1p 4900mAh 20C pack. after 1 charge/discharge its now showing only 4 cells when i connect to my charger which is a Thunder T6 6 cell charger/balancer (pic below) this charger has worked flawless with my 2 other packs i have which are for my slash they are 2 cell lipos. Is there some test i can do to find out if i really have a bad cell? Currently the cell is discharged i used the castle creations mamba monster ESC with the voltage cut off set correctly to 15v for a 5 cell pack and it stopped running just like my 4 cell did yesterday when it got to low. Not sure what to do at this point. I know the charger has Lipo Balancing/Lipo Charge/Lipo Fast Charge/Lipo Discharge/Lipo Storage settings i have only ever used lipo Balance on any of my packs. There is also a settings that i cant really make sense of, it reads like this (silly chinese manuals) Heading is as follows:
Voltage Balancing and monitoring during the discharge.
The processor monitors the voltage of the individual cells during the "storage-mode" and the "discharge mode" of the lithum battery pack. It tries to normalize the voltages to be equal. For this feature, the individual plug of the battery pack should be connected to the individual port of the charger. (is this talking about the balancing port? any way here is the rest) If the voltage of one or more of the cells varies abnormally during the procedure, it terminates the process forcibly with the error message. If this happens the battery pack contains the bad cell, or the bad connection of the cable or plug. You can easily know which one cell is bad by pressing INC button at time of showing the error message.
This is word for word from the manual. At any rate i always charge my packs at what i believe is 1C which in the case of the 5 cell pack is 4.9 AMPS because its a 4900mAh pack (correct me if im wrong). Do i need to cycle (charge/discharge) a pack before i use it? I had thought Lipo was different. HELP!
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
Mentat
Brushless Mentat
Mentat's Avatar
06.24.2009, 08:21 PM
WOW 30 views now answers LOL
skellyo
skellyo's Avatar
06.24.2009, 08:25 PM
I would suggest trying to measure the voltage of each cell at the balance tap. If you can only measure 4, it's likely your problem that you have a disconnected balance tap wire.
Mentat
Brushless Mentat
Mentat's Avatar
06.24.2009, 08:28 PM
I have a few diff devices i can use to measure, not sure how tho. Which one should i use? and how?
Mentat
Brushless Mentat
Mentat's Avatar
06.24.2009, 08:29 PM
OH also my charger gave me this info on the cells. Ideals?
06.24.2009, 08:31 PM
Of the 6000 odd members, only a few dozen are regular posters, so....
There is a very simple trick you can perform; charge the lipo as a 4s pack until the voltage of each cell is at the nominal level or just over- thats 3.6v each, so the total voltage will be 18v. Now, stop the charge and restart it- the charger should recognize that you have a 5 cell pack and ask you to confirm this before it starts the charge.
Im assuming when you connect it up and select 5s lipo, it only reads the pack as a 4s item? Thats due to the voltage of the pack being lower than the nominal/ resting voltage of a pack that size; the cells are discharged to ~3.0v per cell, but the charger is looking for 3.6v (or 18v vs ~15v, however you want to look at it), so it thinks you have a smaller voltage pack connected up.
Its a fairly common issue, I get the same thing with my Bantam BC6 charger, so I just use that trick and it works every time. You can also charge the pack as a nimh pack at 1c until the voltage hits the needed level, then change it to the correct lipo setting and finish the charge.
Mentat
Brushless Mentat
Mentat's Avatar
06.24.2009, 08:34 PM
I like your ideal. so i just set my charger for 4 cells @ 4.9 AMPS and let it do a full charge? Once done the try to charge again as a 5 cell? I should still use the LIPO BALANCE SETTTINGS right? Thanks for all the help you have give/suggested in all my other threads Suicideneil
06.24.2009, 08:32 PM
I love being right all the time
big greg
06.24.2009, 08:36 PM
good job neil...
06.24.2009, 08:39 PM
Yes and no. Set it for 4s lipo and 4.9amps, but only charge it until the cell voltage is 3.6v, and the total voltage is 18v. Then you MUST stop the charge and restart it as a 5s lipo at 4.9amps. Make sure the balancer plug is connected and you select the 'balance charge' mode/option.
Originally Posted by big greg
good job neil...
I try my best- since it happended to me the first time I used lipos, I kinda scratched my head and had a brain wave, and then after doing some research on this forum I saw people suggesting the exact same solution. Its only easy when you know how..
Mentat
Brushless Mentat
Mentat's Avatar
06.24.2009, 08:43 PM
suicideneil, thanks so much, i deleted the other post, i figured this one was way to long and nobody wanted to take a crack at this issue. Im charging now at the settings you specified, Im not to sure on when it will be at 3.6v tho. People keep taking about using a meter to check the voltage but i am not sure on how to do this. suggestions?
Mentat
Brushless Mentat
Mentat's Avatar
06.24.2009, 08:57 PM
I LOVE YOU MAN! That fixed it. So now comes the part about Low Voltage CUTOFF. what is a good setting being that 3.0 seems to be to low for this pack. anything about that? like 3.2 3.3?
06.24.2009, 09:00 PM
Just keep checking the pack, shouldnt take more than 5-10 minutes- you should be able to view the individual cell voltages like in your pictures above during the charge.
As for the other question, you should have two nice pointy probes with the multi meters, a red one and black one ( + and - ). Set the voltage on the grey one to the '2v' option (adjusts the sensitivity), and plug the probes into the 'A' (red) and common (black) sockets. Now, on the lipos balancer plug, there should be 5 red wires (or coloured wires) and one black one. Place the tip of the black probe onto the metal tab of the black wire in the balancer plug, and the red probe onto each red wire's tab, one at a time & in sequence. You should be able to then see the voltage of each cell, or the combined voltages as you go along the line of tabs so to speak (just deduct the first voltage from the second result, and the 1st and 2nd voltage from the 3rd result to work out the individual voltages of each cell).
Your charger should be fairly accurate with the cell voltages, but you can also buy awesome little voltage checkers that plug into the balance plug and tell you the voltages too:
http://www.hobbycity.com/hobbycity/s...y_Monitor_2-6S Good
http://www.hobbycity.com/hobbycity/s...itor_2-6S_Lipo Very good
http://www.hobbycity.com/hobbycity/s...~6S_(Version_2) Really good
http://www.hobbycity.com/hobbycity/s..._Polymer_Packs Awesome
Mmm, man love...
3.2v per cell should be fine- 2.7-2.9v isnt too bad, but it would be better if they stayed around 2.9-3.1v once they are discharged. Seems like 2 cells are little bit weaker than the other two, but not by much, and since they arent matched cells, thats pretty normal behaviour.
06.24.2009, 09:04 PM
Mmm, man love...
Nice Neil! I gotta get me one of those....the third one down looks promising!
big greg
06.24.2009, 09:06 PM
your charger should show you individual cell voltages, or just stop the charger at 18v
