Bullet-Proof Diff press release with pics
Electric Eel
Bullet-Proof Diff press release with pics - 08.18.2009, 12:52 PM
Finally, some pictures and info right from HPI!
29T/9T R and P. They look like Cens. Huge teeth. And hardened steel, not cast like Cens. We may have a winner.
http://www.hpiracing.com/press/102692.html
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.18.2009, 01:30 PM
Wowsers, for 90.00 + tax for 2 sets they dam well better be bullet proof.
Wonder if these could work in a Lightning Stadium Pro diff set up ????
Semi Pro
Semi Pro's Avatar
08.18.2009, 03:07 PM
the spiral cut diff gears in your lsp are bullet proof if you shim them right i have been useing them for years with no failures
there is no such thing as bullet proof gears, they all will ware down and need shimming or they will fail
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.18.2009, 04:13 PM
LOL ?
I never have problems with wear, Gone thru many bearings though !
I have problems eating gears when I brake the outside diff case under extreme jumps. I was thinking the straight cut gears would hold up better after the case breaks. The spiral cut gears always get the tore up on the ends.
Semi Pro
Semi Pro's Avatar
08.18.2009, 11:11 PM
LOL ?
how often do you servise your bearings?
i went to wala wala cermaics after i had a stock bearing fail and since then i havent ever had a diff fail, mine is used for bashing too
sikeston34m
sikeston34m's Avatar
08.18.2009, 11:22 PM
I wonder if these will fit the Hotbodies diff center........that the RCM case takes?
Hmmm..........
wallot
wallot's Avatar
08.18.2009, 02:02 PM
savage problem is not diff strenght. its bulkheads. they develop quite a play very fast leading to diff failure. you either need to reshim them once every few runs or get FLM hybrids.
every diff will fail if it has too much play. seen mugen diffs fail as bulheads did allow quite a lot of play. however in this case it was after 15 races :)
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
08.18.2009, 04:53 PM
I like how they "recommend" swapping out both at the same time. The ratios are different from 9/29 to 13/43. Not a huge difference but this truck does not have a center diff, so one set of tires will turn fast than the others... 3.22 vs 3.31.
I do agree that bulkhead flexing is a big issue. Either the flm or gh bulks would cure that. I will probably get a pair of these diffs for my 5th scale savage build, along with the al bulks it should help with the extra weight... Hopefully!
Finnster
KillaHurtz
Finnster's Avatar
08.18.2009, 11:44 PM
Those are diff gears the likes of which God has never seen... :)
Machined Cen diff gears basically? Badass.
Mucho dinero tho.
