baja brakes on a xxl savage?
fatboyelroy
baja brakes on a xxl savage? - 10.26.2009, 07:41 PM
Does anyone have any experience or knowledge with adding disc brakes from a baja to a savage? I am working on a beast of a brushless project and esc brakes simply won't do.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.26.2009, 08:25 PM
We would like to see the "Beast of a BL project"
Sorry no clue about the brakes question.
fatboyelroy
10.27.2009, 04:54 PM
I've been gathering the "nuts and bolts" of the project along with some CAD work. But here is what the heart of this 8WD "beast" will consist of.
4 1527 1.5d 5mm shaft neus (still trying to hunt down 2 more, the motor to the far right is all wrong. it is a 1.5 y with a 8mm shaft) mounted with flux motor mounts
4 MMM V3 escs
brushlessboy16
brushlessboy16's Avatar
10.27.2009, 05:11 PM
Do you have a mental condition that makes you need that much power?
kiss your diffs goodbye!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.27.2009, 05:22 PM
WOW, I gotta see this !
Keep us posted.
riverat1540
riverat1540's Avatar
10.27.2009, 05:27 PM
lst or muggy diffs can handle it within reason
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.27.2009, 05:41 PM
(4) 1527 1.5d's are NOT within reason
Hey FBE, what voltage you plan on running, What packs ETC ?
Curious to the layout of the drivetrain for 4 BL motors ??
JThiessen
JThiessen's Avatar
10.27.2009, 06:09 PM
I was actually just at the hobby store and was looking at the 5B on the counter to see what parts I could possibly use off it. Unfortunatley, I didn't look at the brakes at all. I did kinda snoop around the rear diff to see if one could use those in a 4WD application - but unless you were to build a bulkhead for it, it can't be mounted upside down. Steering components looked like a possiblity though.
Edit:: BTW, HOLY S#*$($! "Beast" is not an appropriate noun to use for what your looking at doing......
fatboyelroy
10.28.2009, 04:47 AM
Thank you guys for the input and enthusiasm. I will probably end up using this brake set or these with some modded aluminum hubs and axle carriers.
I am not sure if I want to use a123s or lipos. I want to keep it at around 6s.
I will be using an E-maxx aluminum flm tranny case and gmaxx single speed conversion with a set of ultramaxxed Gen III metal gears. And yes an upgrade to the diffs is a must.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.27.2009, 06:20 PM
Theres actually some decent pictures here, half way down the page to the gallery.
http://www.hpiracing.com/kitinfo/10600/
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.28.2009, 08:24 AM
So safe to say this prodject is based on a Emaxx chassis/running gear ?
A LOT of upgrades will be nessasary then, have you considered a LST2 platform with a center diff or installing the FLM trans ?
