Losi 8b diff gears
zviper
Losi 8b diff gears - 11.10.2009, 05:36 PM
well i have 2 blown out drive bearings and the gears on the inside are rounded pretty bad. i have some spare hellfire diff gears they fit but i just want to know if is compatible. or is it just too weak for brushless?
brushlessboy16
brushlessboy16's Avatar
11.10.2009, 05:41 PM
shim them correctly and they will be fine, my 8ight has an entire season on the diffs- no problems as of yet.
zviper
11.10.2009, 05:48 PM
im still unshure what shimming is.
brushlessboy16
11.10.2009, 05:50 PM
Shimming is using small very thin washers(shims) to set the gear mesh inside the diff properly. too loose and you will strip gears, too tight and the gears will bind up
zviper
11.10.2009, 05:56 PM
these http://www.greathobbies.com/producti...od_id=TMLA3501 ? if so i have four in there, one on either end of each of those nothched pins.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.11.2009, 12:05 AM
I've had my 8ight for over two years now and neither of the gears inside or out of the diff have shown any wear, and neither have i ever used shims. Are you talking about the gears inside the diff or outside? If it is on the inside, make sure your diff has a enough diff fluid. If its on the outside, its probably the blown bearings that cause it.
Area 52 Ranch Raceway
T.R.C.R.
zviper
11.11.2009, 12:08 AM
im talking about the gears inside the diff.
JeffEmbracedDC
JeffEmbracedDC's Avatar
11.16.2009, 03:44 AM
Those shims are FOR the gears on the inside of the diff. The 4 small gears (spider gears) ride on shafts inside of the diff. Those shims can be put on the outside of the small gears on the shafts to force the gears to mesh tighter with the larger output gears. Less shims = looser, more shims = tighter. If it's too loose or too tight they will wear prematurely just like incorrect gear mesh for your spur/pinion.
I've also been running at 8 for probably 40 runs. never had an internal gear problem.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
zviper
11.16.2009, 12:05 PM
ok thanks for clearing that up, i got my 8b 2.0 second hand. it didnt even have any grease in the bulkhead
