KM Baja VS HPI 5B -
05.14.2009, 02:00 AM
What are your thoughts on the clone vs 5b debate? I have my personal opinions (which has been formed off opinions of others, and videos  )
Lets here yours.
Personally, I think that if you know what you're doing, and can fix a couple minor errors, your good to go. Simply boiling the A-arms, tightening screws, and making sure everything is good to go.
I say this because I either want to get a used 5b for around $550-$600, or a clone on E-bay for $650 shipped with a Pipe and ported to a 29cc.
Videos haven't really proven anything to me. They look the exact same, and when it comes down to it, the KM looks like a good buggy. All of the HPI parts say "Made in ____ " anyways. I doubt that foreign places have nothing to do with the building of the 5B.
05.14.2009, 07:46 AM
I was wondering the same thing. They look exactly the same, and all parts are interchangeable.
05.14.2009, 08:02 AM
I can't say about the clone but my good friend has the 5b SS and he loves it. Other fellas have tried to upgrade there machines but it does'nt go like the SS.
WARNING: May become violent.
05.14.2009, 09:17 AM
Originally Posted by TexasSP
I also predict alot of biased opinions...
RIP- Tammy (9/14/08)
05.14.2009, 10:19 AM
since parts are interchangeable I would buy the cheaper one and just upgrade to 5b parts IF anything breaks.
05.14.2009, 10:29 AM
If you haven't run gas before just remember to change the clutch every 3-4 runs (IIRC). My mate buys brake pads (real car) and cuts peices off and re-shoes the clutch. If you upgrade and get a 30cc big bore kit on a decent motor, you'll need to change the clutch before one full tank of gas.
The other thing is expence (sp?) I beleive large scale buy parts less but are more expensive. If it works out the roughly the same i don't know
05.14.2009, 11:39 AM
from what i hear the clone is just as good.
As for the "ethical support HPI" debate....the way i see it, im not going to pay a grand for the original, but if i guy the clone and purchase the hpi original parts...im helping out.
05.14.2009, 11:43 AM
Yeah, people who want a hpi baja will buy it, the clones will sell to people who do not have the money to buy the hpi version.
As far as supporting HPI goes, you can take that to an extreme and say that hobbyists should pick just one mfg and only buy cars from that one mfg. But that would be dumb...
And it is not like HPI has started the 5th scale class, or has a ton invested in the baja design. It is not that revolutionary.
I bought a used baja, so who am I supporting?
5,280 feet above sea level
05.14.2009, 12:11 PM
I have one and looking back I may have been better off getting a SS.
I got mine with a pipe to the door for $550.00 it is a King Motor Baja 5b clone with 23 cc I bought it back in Nov of 2008.
I had to replace both upper and lower ft “A” arms with RPM (I broke both lower arms the first day out when I hit a small tree I don’t think the HPI arms would of broke with the same collision, but who knows) I also replaced both ft hubs with HPI ones (the bearing were sloppy in the KM hubs).
I also had to replace the clutch after 2 tanks (I used HPI clutch with 8k spring)
I had to replace all 4 wheels (hex striped out, HPI wheels have a metal ring around the hex)
I also had to re-bild all 4 shocks after I bent the Rt Ft shock shaft (they had no oil from the factory and the piston hole is way to small & needs to be drilled out)
I then had to replace the rear upper trans plate (the KM plate is aluminum but is very thin and cracked)
I also had to upgrade the raido system (RX, TX, throttle and brake servo, and steering servo I also upgraded the receiver battery) some of this is a wash because (I think) the SS does not included any electronics.
I then did some upgrades like air filter, fail safe, pull starter outerwear, ect (these would be need with a HPI as well)
Then about a mouth ago I had a lean seize (damaged piston and cylinder)
The KM motor is a clone of the fuelie 23 I had the motor tuned on the rich side ran good gas with good 2 stroke oil and cleaned the air filter after every run so I don’t think a true fuelie would have seized on me.
I have yet to run a full gallon of fuel thru it yet because of all the problems I have had.
I have not taken the time to add up all I have spend because I don’t want to know.
I must say there is nothing like running a 1/5 they have a lot of power, long run time and are BIG, it like driving a RC ATV.
I think I will order a big bore kit and try my luck again.
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
05.14.2009, 12:12 PM
Single Mothers..
And I dont see the point of this- they both probably come out of the same factory in china.. Either way your supporting that factory...
05.14.2009, 03:54 PM
I was thinking the clone was just as good, until I read Snowmans post..... I have checked out the large scale forums, and the HPI Baja forum. One forum did not allow clone discussion, the other one I got a bunch of simple replies "It's a clone" that did me no good.
Maybe 1/5 is out of the question, but who knows... With that list of parts, it's not looking so good.
05.14.2009, 05:09 PM
I posted my experience with the clone, however I have heard good things about them and the new ones look a little better them mine.
This has a lot of GOOD info:
http://www.rcuniverse.com/forum/m_7249314/tm.htm
PS I did order the big bore kit for mine today, I will see how it turns out.
Brushless Rustler
AX10
Venom Creeper
Slash 2WD
Slash 4WD
Something, anything, nothing
05.14.2009, 05:20 PM
From what I understand the KM Baja is just one clone and not all clones are the KM. Either way HPI did nothing revolutionary with the design and as such they obviously don't have a patent on the product or else it wouldn't sell in the US. I also saw HPI Europe's response which I find silly because the clones obviously sell in Europe as well. My guess is that the clone is really the original and HPI contracted the chinese plant to make it and brand it for them. I am sure there were probably some changes and maybe a little stricter QC but that's about all I will give it.
05.15.2009, 04:57 AM
Yes there are a number of clones which leads me to agree with TexasSP that there is one blue print for a car made by several companies. Just the running gear needs to be upgraded- electronics, tuned pipe, and possible weak pionts...etc.....
Hybrid Mode
