O'Donnell Z01B shock dimensions?
JoFreak
JoFreak's Avatar
O'Donnell Z01B shock dimensions? - 08.01.2010, 10:20 AM
Hi!
Still looking for cheap and good shocks for my SC truck.
Does anyone have the measurements for the O'Donnell Z01B front and rear buggy shocks?
-front
overall length:
hole to hole length expanded:
hole to hole length compressed:
outer diameter of shock body:
outer diameter of spring:
diameter of shaft:
-rear
overall length:
diameter of shaft:
Thank's a lot!
golfito
golfito's Avatar
08.01.2010, 11:51 AM
Hello, I hope you achieve understand each other ...
I will be using the google translator ...
The shock that I am measuring are the z01b team :
Front:
total length: 110mm
orifice hole extended length: 100mm
hole to hole compressed length: 74 mm
outside diameter shock body: 19.5mm
the diameter of the springs of both is: 25mm
diameter of the capsule top: 22mm
4 mm diameter shaft
Rear:
total length: 134 mm
hole to hole extended length: 124mm
hole to hole compressed length: 90mm
4 mm diameter shaft
I hope to serve you
Greetings from Argentina.
JoFreak
JoFreak's Avatar
08.01.2010, 11:58 AM
Thank you very much, I understood everything perfectly.
Greetings back from Germany.
