Arming problems with Schulze 18.97KW
Byte
Arming problems with Schulze 18.97KW - 05.07.2010, 09:04 AM
Hi,
A few months ago I bought a Schulze 18.97KW of eBay. Yesterday I soldered a Deans connector to it and some bullet connectors. Today I tried to arm it to the Transmitter, but with no success... I tried about every setting on the ESC, I changed the motor, changed the receiver, checked the wires. But whatever I did, the motor won't do anything. I tried the motor on another ESC (with the same receiver), and the motor worked on that one, so the Schulze ESC has to be the problem.
The manual of Schulze sucks imo, I might done some things wrong there, but I don't think so.
Quote from the manual:
If you have a transmitter with adjustable servo travel we recommend that you set throttle-servo
to normal full travel, i.e. +/- 100%. Adjust Multiplex servo center pulse width to 1.5 ms (= -
22% center or use uni-mode).
The ipsu consists of two components:
a) The DIL switch bank for setting the operating mode (configuring the controller to the application
and motor) and
b) automatic transmitter stick travel setup.
Point a) is explained in the following pages; point b) includes two different procedures, of
which b1) is also explained in the following pages:
The stick travel setup process is based on the previous standard procedure when the unit is
first switched on, and is fully automatic:
b1) Under normal circumstances you simply proceed as previously: 1. Transmitter to stop,
2. Switch on receiver, 3. Connect flight pack / drive battery (future confirms this with ”Power-
On” tones = flight pack / drive battery connected), then learns the Stop position and confirms
this with a beep; it is then armed, 4. Hold model in launch / start position, 5. Apply fullthrottle
(future learns full-throttle point, confirms with brief drop in rotational speed), 6.
Launch / Start model. The process configures both the brake point and the full-throttle point,
so full stick travel is always available when you operate the motor, giving ultra-fine control.
b2) If you find the brief motor speed drop at the full-throttle setting disturbing (confirmation
of learned full throttle position), or don’t wish to apply full throttle at launch / start, there is
an alternative method: set the transmitter stick to the full-throttle position before you switch
on the receiving system and connect the flight pack / drive battery. After the ”Power-On”
tones the future emits two beeps (to confirm it has learned the full throttle position); the
transmitter stick is then moved to Stop, and the future emits one beep (to confirm it has
learned the brake position); the controller is now armed, and the model can be launched or
started at any throttle position.
In the model car and boat programs the controller only learns the neutral point; the full-throttle
position is a fixed margin from the learned neutral point.
At 1. it says 'Transmitter to stop', this means 'Pull the trigger to full brake' doesn't it?
At 2. it says 'Switch on receiver', I haven't got an on/off switch on the receiver, it's always on.
At 3. it says 'Connect battery (ESC confirms this with Power-on beep', I get the Power-on beep if I connect the battery
After that it says 'then learns the Stop position and confirms
this with a beep; it is then armed', I don't get a beep here, it does nothing.
Anyone knows why I don't get a beep here? What am I doing wrong? I really don't know what I should do...
My electronics used are:
Schulze 18.97KW with UBEC
Hacker C40 brushless motor
Turnigy 5000mAh 3S 20C battery
Futaba 3PKS with 2.4GHz fasst system
I appreciate your help.
- Patrick
