Rule of thumb for CC-Neu motor heat?
loa
Rule of thumb for CC-Neu motor heat? - 06.23.2010, 11:33 PM
Hello,
Just installed my 2200kv motor in my Revo 3.3 conversion. I have decently low gearing for bashing (16/40 on 5S, with a MMM), and although the motor temps are much much cooler than the 9XL I had before, it still got quite hot after hard bashing.
I don't have a temp gun, but is there a rule of thumb (like: if you can keep your thumb on the motor for 5 seconds, it's ok) I could use?
Thanks
Loa
Kcaz25
Kcaz25's Avatar
06.24.2010, 12:14 AM
Get a temp gun, thats the rules.
You've got a $600 truck, but haven't spent $19 on a temp gun? Do it.
THIS is the one I have. I reccomend it.
Pdelcast
Pdelcast's Avatar
06.24.2010, 12:54 AM
Originally Posted by loa View Post
Hello,
Thanks
Loa
Loa,
If you can touch it for five seconds, you are hardly pushing it.
The motor temp should be kept under about 100C (the magnets are rated operational up to 180C.)
Patrick del Castillo
President, Principle Engineer
BP-Revo
BMW M Power!
BP-Revo's Avatar
06.24.2010, 03:46 AM
Loa,
100C !?? Wow.
loa
06.24.2010, 07:41 AM
Oh... So much more than 600$ :-D Anyway I got the point. Towerhobbies from Canada = you pay more for shipping than your item, but I ordered a nice one from Dealextreme. Some ppl in the comments said they used it for RC.
Thanks for the numbers Patrick!
Loa
TexasSP
Something, anything, nothing
TexasSP's Avatar
06.24.2010, 09:30 AM
Temp it and be done with worries.
www.cubicle101.com
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
06.24.2010, 11:51 AM
Originally Posted by texassp View Post
temp it and be done with worries.
+1..
simplechamp
simplechamp's Avatar
06.24.2010, 06:17 PM
Agreed, everyone should have an IR thermometer in their toolbox.
itbvolks
06.25.2010, 11:54 AM
You know what would be even nicer......
If said IR thermometers actually read the same temp... Emissivity be damned!
Pdelcast
Pdelcast's Avatar
06.25.2010, 11:59 AM
Yeah, that's a big problem with IR thermometers -- temp a shiny surface and the temps are off -- WAY off. We have that problem with some prototype motors we build -- we don't want to spend the time to have the case anodized, so they ship them with just bare machined aluminum surfaces. And then you can't get an accurate temperature with an IR gun anywhere on the case.
Always pick a black, non-shiny surface (if possible) to temp with an IR thermo -- then you will get a reasonable answer.
loa
06.25.2010, 12:02 PM
Are the caps on the CC Neu motors good spots?
Pdelcast
Pdelcast's Avatar
06.25.2010, 12:08 PM
Yep. :)
loa
06.25.2010, 12:09 PM
Great, thanks for the tip!
fastbaja5b
fastbaja5b's Avatar
07.14.2010, 10:40 PM
Also depends on the thumb! I'm a bit of a wuss like that, I think my wife's showers are too hot etc I find a motor too hot to touch for 5 seconds when a contact sensor like on a DX3S shows a temp of only 110-120f!
Say Less, Do More.
Unsullied_Spy
Unsullied_Spy's Avatar
07.15.2010, 01:01 AM
I leave my E at 77 (normal for the Flashpoint) and go off the motor can and keep it under 160. A little anal but I don't burn up motors!
