Rookie brushless racer in need of opinions
billybob
Rookie brushless racer in need of opinions - 07.26.2010, 10:34 PM
I have a 4x4 Slash running 10/40 or 9/40 mod one gears...3s 6000mah lipo...
My VXL esc keeps over heating no matter what gearing I run. My friend Brushless Boy (Ben) has suggested putting capacitors on the power leads to control the voltage ripples from my hard driving style...
I am on a very tight budget due to a little one on the way so I have to work with what I have at the moment...
Any thoughts???
bdebde
That's All Folks!
bdebde's Avatar
07.26.2010, 10:47 PM
Caps may help. I think you may want to try an external bec. I know the old mamba max would get hotter on 3s and a bec would help keep it cool.
brushlessboy16
brushlessboy16's Avatar
07.26.2010, 11:45 PM
I also suggested that to him. he didnt post it
billybob
07.26.2010, 11:54 PM
Sorry posted this before you talked to me...
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
07.27.2010, 12:15 AM
There is also a fan made specifically for the vxl esc and is recomended when running 3s. However a fan is just masking the problem, the problem being that you are drawing more current than what the esc is capable of handling. I would recomend going back to the stock mod.8 gearing and running a lower ratio
fastbaja5b
fastbaja5b's Avatar
07.27.2010, 03:51 AM
I thought Traxxas advised when running 3s Lipo, the fan over the ESC heatsink was essential, not optional.
Say Less, Do More.
brushlessboy16
07.27.2010, 07:39 AM
He has the fan.
nitrostarter
nitrostarter's Avatar
07.27.2010, 09:06 AM
I do think the VXL system is on the brink of being a little inadequate for the Slash 4x4, basically a small buggy...
I know you're on a budget, so I would try the fans on the motor and ESC. What connectors are you using? Maybe solder on some 5.5mm bullets for even less resistance. What lipo's as well? New or old?
Try finding the past path of least resistance. Otherwise, I think you'll have to save up and get a different motor. A Feigao 9L would make a good choice on 3s in the Slash 4x4 and could be had for like $60 or even cheaper used.
N. Rustler conversion
brushlessboy16
07.27.2010, 09:50 AM
I set him up with an aveox (1509 sized) of 2768kv set up to run great on 3s. But the vxl esc will not run the 4 pole motor.. He has every component aside from an esc. I'm gonna try the basic bandaids to get the esc to last until he can buy a better unit.
Going to install some low ESR 3900uF capacitors to help kill some of the current ripple, and install an external BEC and not use the crappy linear regulator in the vxl. Scrubbing 12.6v to 6.0 creates a lot of heat. I think it will make 15 minutes
billybob
07.27.2010, 08:57 PM
We did the External BEC today...Over heated in the grass...We are going to the track tomorrow for a t and t...
If it over heats we are going to try Capacitors. Hopefully that works! If it isnt already fixed... Having Ben at my side has helped greatly! And He def knows his s$!t !!!!!!
07.27.2010, 09:08 PM
He learnt from the best...
RC-Monster; The Encyclopedia Brushless
billybob
07.27.2010, 11:07 PM
Yes sir! My main goal is to get it working right for the RCmonster race...I want to have a good showing and not have to worry about overheating constantly.
Im looking forward to not hearing all the nitro stuffs and im shur my girl will too
Who knows maybe ill learn a thing or two!
brushlessboy16
07.27.2010, 11:24 PM
Glad I didnt learn grammar from you Neil, bloody wankah'!
