Need Mech Brake Advice and pinion/ motor shaft help...
Jahay
Need Mech Brake Advice and pinion/ motor shaft help... - 03.08.2011, 10:18 AM
Need some quick advice regarding my pinion sitting on my motor shaft with the brake assembly on the new motor mount.
If you look at the pics below...
You can see that with the dual brakes fitted, i will need roughly a 15mm motor spacer to push my motor away from the mount in order to clear the brake assembly.
Dejan is making the custom size spacer for me...
But this means the pinion will have to sit half way off the motor shaft too.
Is this a very bad idea? considering im running 9s? Should i just go with a decent single brake setup in the front?
This does seem like a bad idea, and i should really run a single brake disc and pads instead.
If so... What are the toughest brake pads and discs out there that work with my spider diff axle and can handle high temps with no fade???
THANKS
