This is a little scary...
simplechamp
simplechamp's Avatar
This is a little scary... - 02.26.2011, 10:00 PM
Saw this on the HobbyKing blog while browsing around:
"New B-Grade LiPo.
Same quality and reliability as eBay packs.
Price: Dirt Cheap
Cycle Life: 50+ only
Good for low discharge testing and not-so-critical flights."
They say good for low-discharge testing, and then slap a big 40C rating on it. You know there will be plenty of people who won't even read the description. Same quality and reliability as Ebay packs is NOT a selling point IMO! I'm already starting to smell scorched electronics and venting Lithium gasses.
02.26.2011, 10:07 PM
Suprised it does not have flames on the sticker... Like those D grade packs brand P sells...
josh9mille
josh9mille's Avatar
02.26.2011, 10:36 PM
wow thats crazy!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
02.26.2011, 10:52 PM
Folks new to the hobby and dumbasses who refuse to do some reseach will but the hell out of them. MA finially has some real competion !
brainanator
brainanator's Avatar
02.26.2011, 11:58 PM
where do I sign up?!?!
Will they start my car up?!
whitrzac
Can't catch this...
whitrzac's Avatar
02.27.2011, 04:56 PM
I just jump started my car with a 4s 5kmah this morning
the batt was hot enough to melt snow....
02.27.2011, 04:59 PM
Originally Posted by whitrzac View Post
...the batt was hot enough to melt snow....
So, 32.1*F?
whitrzac
Can't catch this...
whitrzac's Avatar
02.27.2011, 05:10 PM
So, 32.1*F?
*failed at thinking of a smart___ comment*
It was 90*f+ after 1-2min...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
02.27.2011, 01:55 AM
Oooo! Check out the new self-powered rocket motor ignitors!
bigsteel
02.27.2011, 03:13 AM
Are the "not so critical flights" what happens when you fling it off your charging station as it bursts into flames?
simplechamp
02.27.2011, 03:45 AM
If the battery dies you lose control and crash. Which to me says it's critical to have a good battery EVERY flight.
I could understand marketing these as Tx/Rx packs, but then they put the 40C rating on the label which totally contradicts the "good for low discharge testing" statement.
josh9mille
josh9mille's Avatar
02.27.2011, 05:41 AM
Well ever since MA introduced 150c lipos, 40c IS low discharge
02.27.2011, 12:44 PM
I am just wondering when MA are going to bring out a lipo that you can use to power a charger. Then you can use that lipo to charge itself. A self charging lipo. It will be configured in series to power the charger and also in parallel so that the really good balancer circuit in the hyperion does not need to be used. Cause parallel charging is the way to go. And 500 bucks would be a steal for a self charging lipo.
brushlessboy16
brushlessboy16's Avatar
02.27.2011, 12:46 PM
At least they are honest about what they are selling instead of trying to put some rediculous rating on them and up the price..
I applaud them for just telling the truth.
sikeston34m
sikeston34m's Avatar
02.27.2011, 01:36 PM
True! But the buyer should be educated in what to look for when they start to give up.
There's all kinds of crooked things going on in the battery industry.
I recently purchased 3 protected 3000mah 18650 cells for a flashlight that I bought.
The flashlight would only shine for a minute or two before the cells hit their built in low voltage cutoff.
Discharge testing at 1 amp only showed 150 - 200mah of capacity.
Protected cells that were counterfeit. My guess is "fresh" out of the recycle bin.
Alot can be hidden under shrink and end caps.
Check this out.
Looks good so far.
Photobucket
Under the cap, notice the multiple weld marks and the scrapes to remove them, before the new cap was added.
Photobucket
Yes, on the other end too. There's even some rust.
Photobucket
Notice the dents on the naked cells. It's like they were all dumped together in some large bin. This doesn't happen on the production line.
Also note, different lot dates on the 3 cells. Definately not the same run. Probably not even the same brand.
Photobucket
Who's going to bring them to justice though?
