revive LiIon laptop batts?
whitrzac
Can't catch this...
whitrzac's Avatar
revive LiIon laptop batts? - 05.22.2011, 09:10 AM
I have a laptop coming with a bad batt. (alienware M9750) new ones on ebay are $90+
Is there anything I can do to "revive" the batt. and were is a good place to buy just the cells? HK doesn't stock stuff like that...
sikeston34m
sikeston34m's Avatar
05.22.2011, 09:22 AM
I looked at a few of the packs for that laptop.
6600mah @ 14.8v is 4S3P using 2200mah 18650 cells.
I could have fixed you up with a good deal not too long ago, but sold all my stock.
I would go with one of these cell choices:
Sanyo 2600mah
Sony 2600mah
The LG cells seem to be pretty good too.
Unless you find a REALLY good deal on the cells, you're not going to save much at all.
Just remember, cheaper isn't always better.
To "revive" the pack? When 18650 cells are dead, they're done.
I would open the pack before ordering anything. You need to be sure it is a cell issue and not a BMS issue or even a charging issue.
Ferret
05.22.2011, 01:11 PM
I "revived" laptop batteries by starting to charge them with the NiMh of the chrger and after the voltage rose a little bit switching to LiIo mode.
pinkpanda3310
pinkpanda3310's Avatar
05.22.2011, 07:03 PM
If cheap and nasty is your thing... you cuold try going to tool repair shop's and ask for disfunctional Makita Lion battery packs. They are 18650's with 1500mah. Just check each cell before using.
whitrzac
Can't catch this...
whitrzac's Avatar
05.22.2011, 08:00 PM
I'll have to open the batt when I get it to see what cells it uses...
I know your not "supposed" to use lipos, but would there be any harm in useing something like a 4s pack?
this is the batt I'm talking about... $90 is the cheapest I've seen new batts...
http://cgi.ebay.com/NEW-Alienware-M1...item2c5bc0c2ff
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
05.23.2011, 03:12 AM
Not tons better, but how about $75 for a new one?
http://cgi.ebay.com/New-Battery-Akku...item3f032b174e
Not sure if that's what you're looking for or not, but it seems to have the same part number. Only problem is it's from China, so will probably take forever to get there.
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
whitrzac
Can't catch this...
whitrzac's Avatar
05.23.2011, 11:15 AM
J57ltr
05.27.2011, 12:37 PM
While you can do this (and I have) they typically will not hold a charge, and if they do they will not put out even half their capacity. Like sikeston said when they are dead they are dead.
Oh, and good luck getting them to stay in balance.
Jeff
