new to brushless
aicecoldone
new to brushless - 04.28.2006, 05:40 PM
i get a emaxx planning on buying Warrior 9920 Brushless Car Controller, Strobe Slipper Kit w/Bearings, Nylon 51 tooth spur gear - Ofna , Feigao 540C XL Brushless Motors, and get UE 6 spider diff, front and back cvds, center cvds, what should the gearing be.
coolhandcountry
coolhandcountry's Avatar
04.28.2006, 06:06 PM
Welcome to the forum.
You may get the steel idlers to if you don't have them.
I don't know how many batteries you running.
The tire size helps to.
Peace!
Country
Help support the
Rc-Monster
Buy here
aicecoldone
04.28.2006, 06:26 PM
12 cells and the stock tires
aicecoldone
04.28.2006, 06:30 PM
or these tires RD Logics pre-mounted "maxx" size tire and wheel combo - studs
coolhandcountry
04.28.2006, 06:51 PM
I would go with a 18 51 gearing. If you want more speed you could go 20 51. I am not sure the motor mount you using or what fits right off. The rd logic are pretty nice. I had some for little while. I had the mulcher look a likes.
Peace!
Country
Help support the
Rc-Monster
Buy here
aicecoldone
04.28.2006, 07:28 PM
stock motor mount
aicecoldone
04.28.2006, 07:34 PM
where can i buy the 18 or 20 pinion rcmonster is out of stock
coolhandcountry
04.28.2006, 07:36 PM
I would email mike. He has some in sometime but not always in stock on the store. He does that to cover the email orders he gets. You could run a 16 but it may not give you the speed you want. It will still be faster than stock cause that is geared close to stock. The 9xl turns more rpm per volt than stock.
Peace!
Country
Help support the
Rc-Monster
Buy here
aicecoldone
04.29.2006, 04:19 PM
how about this motor BK Electronics Wanderer "XL" Brushless Motor with the 10xl wind or the 12xl wind
coolhandcountry
04.29.2006, 06:51 PM
The 10xl is little slower than the 9xl. But would give some better run time.
Peace!
Country
Help support the
Rc-Monster
Buy here
Serum
Serum's Avatar
04.30.2006, 03:07 AM
And if you buy the XL, you might consider taking 23mm rimms for a more durable solution..
aicecoldone
04.30.2006, 05:57 AM
the 14mm are should be fine i run proline roadrage on my fg 1/5 monster and they have been good. i just ordered everything i needed bought the ue diffs bought ue drive shaft front and rear and the motor contoller everything for a total of $800 cad. i will almost have a full supermaxx
Serum
Serum's Avatar
04.30.2006, 06:03 AM
I ruined quite a few, they didn't came up with those 23mm for nothing.. 14mm simple is way to small for a monstertruck.. With aluminum rims it would hold up fine, but with plastic and brushless, they are a big nono.. especially with weaker rimms.
mrtallica
mrtallica's Avatar
Question 04.30.2006, 07:19 PM
Originally Posted by aicecoldone
...planning on buying Warrior 9920 Brushless Car Controller, ... Feigao 540C XL Brushless Motors...
with this set up what would you guys say is "gotta have" in regards to the drive line, I have MIP CVD's (FR/RR) now. also I am looking at getting the FLM extended chassis.
this controller will handle 16 cells yes? I am looking at running 2 x 8packs of GP 4300's
  Send a message via Yahoo to mrtallica
coolhandcountry
04.30.2006, 07:43 PM
The cvds are a good idea. The steel idlers are a must in the trans.
A strobe slipper would be good as well for gearing about a 16 tooth pinion give or take a few teeth for tire size.
The stock diffs hold up ok if you run the aluminum diff cups.
The best is the 1/8 diffs. 23mm hexes are good as well unless you got the aluminum rims.
Peace!
Country
Help support the
Rc-Monster
Buy here
