1515 rear bearing
freddy
1515 rear bearing - 09.18.2011, 01:38 PM
Hi, is it possible to get the rotor in without removing the rear cover?
as i opened mine up just to check for dirt and so on(it was completly clean inside), but i cant get the rotor to hit the center of the rear bearing, have tried all day without any success..
09.18.2011, 07:40 PM
The old novak motors had a plastic sleeve you had to insert down into the motor, then you could slip in the rotor so that the shaft entered the rear bearing with little effort- you could do something similar with the 1515 motor, but the sleeve needs to be stronger and made of non-metalic material ( bit of PVC plastic pipe should work ).
09.18.2011, 07:43 PM
A few sheets of paper should do the trick
bruce750i
bruce750i's Avatar
09.19.2011, 08:24 AM
Yes, Make sure not to drop the brass spacers off the shaft.
freddy
09.19.2011, 09:01 AM
Thanks for all the suggestions, have kind of messed up the kevlar so realy regretting that i dissasembed this thing.
Tried wrapping it in paper, tape, feeler gauge and everything else i could put my hand on that fit inside the hole, without any success. At this point my best bet is to contact castle for repair.
Btw i really dont understand why they are using so strange srews, like those holding the rear end bell, today i was visiting several hardware shops and i couldent find a single fitting wrench.
Its torx but no torx wrech is fitting
ta_man
09.19.2011, 11:45 AM
Probably use those screws so they can apply sufficient torque to get the screw tight.
It is probably a T6. My T7 doesn't fit at all but the T6 is looser than I would expect. So unless there is a T6.5 , it is probably a T6. I got my small Torx bits an an electrincs store but you can get Torx bits in that size from McMaster-Carr for $1.20. (But being in Norway, I guess McMaster doesn't help you much.)
freddy
09.19.2011, 12:19 PM
T6 is way to small and T7 is slightly to large
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
09.20.2011, 12:38 PM
Torx bits usually flare out a bit toward the handle. You could grind down the end of a T6 and end up with something in between a 6 and 7.
brainanator
brainanator's Avatar
09.20.2011, 10:45 PM
aren't the rear endbells epoxied on anyway?
freddy
09.21.2011, 12:23 PM
have given this up so want to ship it to castle with an rev 2 mamba xl, but it have gone two days without any reply,, guess they have allot to do.
freddy
09.24.2011, 06:07 AM
Have they stopped answering mail ore is it only me their ignoring?
BMW318TI
09.24.2011, 04:38 PM
Same here sent a mail 4 weeks ago still no answers from CC.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
09.25.2011, 04:15 AM
I don't see what the problem is! Put the rotor in the stator and wiggle it around till it starts to sit in the bearing and then push it into the bearing. I never took apart my Castle Neu but my Tekno Neu doesn't have a removable rear end bell and I took that apart and put it back together no problem. Don't be affraid of it!
freddy
09.25.2011, 05:38 AM
it just dont want to hit the bearing, i have tried countless of hours and im not afraid of it.
As i mention the kevlar is gone, nor sure if the kevlar is crucial or not but i would rather just ship it in since i already have used a lot of time whit this.
freddy
10.04.2011, 10:27 AM
i know why i couldent get it in.. accually the magnet on rotor had slided forward on the shaft so the shaft was hitting the rear cover.
from all my beating on it i alsmost made an hole in the cover
a new rotor and it slided right in there.
Days of struggle on this motor realy payd off, now if castle would answer my mail so i can ship in my maba xl and mamba monster i wil be happy.
