Castle 6.5mm plugs not a tight fit?
Douwe
Castle 6.5mm plugs not a tight fit? - 10.30.2011, 05:31 PM
I recently purchased a Castle 1717 motor and a Xerun 150A ESC. To connect the motor to the ESC I also ordered a set of original Castle 6.5mm plugs to solder to the Xerun ESC wires.
Now I did the soldering today but now the plugs don't seem to fit/make contact very well. When initially putting the male motor plugs into the female ESC plugs there is some resistance but when the male plug is 'in' I can move the plug back and forth for around 5 mm so there is barely contact between the two plugs (btw, no pun intended here ).
What is going on here? How can I fix this? Maybe use a pair of pliers to bend the female plug for better contact?
freddy
10.30.2011, 07:15 PM
you can widen the male plug
brian015
brian015's Avatar
10.30.2011, 09:40 PM
+1 (4 character minimum??)
crusey_aus
10.30.2011, 08:25 PM
I have had issues recently with the Castle 4mm bullets not fitting correctly
Cheers
10.30.2011, 10:48 PM
Just stick a small hex-wrench into the middle of the male plug and wiggle it around a bit to spread out the prongs ever so slightly = fixed.
Knez
Knez's Avatar
10.31.2011, 12:01 AM
yp, had same issues fix it with "something similar to body redemer only not sharp".. no problems now.
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
Douwe
10.31.2011, 08:25 AM
Ok, I will try that, thanks all!
