esc/motor getting hot
tallyram
tallyram's Avatar
esc/motor getting hot - 06.09.2006, 10:41 PM
i live in florida and it gets around 95 in the afternoon here. that happens to be when i hit the track. i run a 1950/8 with a 12020 and 6s lipo. my gearing is 15/51. if i go to 13/51, will that lower temps and give me better acceleration out of turns?
  Send a message via AIM to tallyram
squeeforever
squeeforever's Avatar
06.09.2006, 10:47 PM
How hot is it getting? Whats getting hot? Motor? ESC? Batteries?
tallyram
tallyram's Avatar
06.09.2006, 11:35 PM
as stated in thread title, motor/esc getting hot. both to around 160-165f. batteries get warm only.
squeeforever
06.09.2006, 11:56 PM
Thats getting kinda hot. Not really sure but to experiment. Thats kind odd that the batteries dont heat up but the motor and esc do. Try and get a 16 and 14 if you can. The heat may have something to do with it though. Do they get enough air? A hole in the windshield would help alot.
Gustav
Gustav's Avatar
Those temps aren't so bad considering the air temp.I'd drop a couple of teeth and run as much air cooling as possible to help it out in the hot weather.
edit;squee,that's a point.it is actually hard to get a 1950 up to that temp so maybe try a 16t aswell.15/51 with revo diffs isn't that low though.
tallyram
tallyram's Avatar
06.10.2006, 12:00 AM
i want to put the monster heatsink on the motor and a fan on the esc. this g2r already weighs a ton though.
edit: also, i'm having a lot of trouble finding the perfect track setup. the g2r chassis sits lower than stock, but the truck weighs more. seems like i have to use to stiff of a setup to keep from severely bottoming out when using the lowest ride height. my setup right now is 40w oil all the way around with green/fr and black/rr, using tallest ride height hole. still pretty soft on landings. should i try 50w oil and leave the springs alone or stiffen the front springs and leave the oil alone?
squeeforever
06.10.2006, 12:04 PM
Alot of people resort to the 120mm springs and about 50wt oil.
tallyram
tallyram's Avatar
06.10.2006, 09:31 PM
thanks squee. i tried 120mm's(purple and pink) and 70wt oil, way to stiff for track. i'll try purple/pink with 50wt oil. any ideas about spring combos?
squeeforever
06.10.2006, 10:01 PM
I use to use blue and silver I think.
tallyram
tallyram's Avatar
06.10.2006, 10:03 PM
was that on a g2r?
06.10.2006, 11:30 PM
I do that for my bashers so there is a stiffer suspension for jumping and such. Even on my lightweight Revo, I had to use the second to stiffest of the 120mm springs (pink or purple, can't remember) in the rear since a lot of weight is sitting back there from motor and most of the batteries.
You have to be careful with ride-height though, especially with a heavy truck. If the springs bottom out before the truck chassis does, you can bend/break the shock end or shaft. With the Nitro Revo's weight mostly on the motor side in the back, landing from a jump wrong can set all the weight on one or one pair of shocks. I like to set ride height so the truck bottoms before the shocks do, but use stiff springs so it doesn't bottom too easily - I guess using the bottom of the truck as a safety. The skids are cheaper and easier to replace than shocks...
squeeforever
06.10.2006, 11:57 PM
Originally Posted by tallyram
was that on a g2r?
No, it was actually on a conversion.
tallyram
tallyram's Avatar
06.11.2006, 12:41 AM
i'm going to the track tommorow. i'll try out a few combos. thanks all, tally
Sylvester
Sylvester's Avatar
06.11.2006, 10:24 AM
I use 120mm blue/rear silver/front with 40 weight oil. I might need to step up on oil, maybe 50 or 60. The shocks get worked in so thicker oil is a must.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
