Muggy chassis
ilpufxit
ilpufxit's Avatar
Muggy chassis - 04.29.2009, 11:24 PM
I'm ready to buy a hardened chassis for my Muggy. InnovativeRC is out of stock. Anyone know where to get one?
Unsullied_Spy
Unsullied_Spy's Avatar
04.30.2009, 12:17 AM
The IRC chassis is the only other one I know of. Why not use a stock chassis?
drkdgglr
04.30.2009, 01:55 AM
if you can wait just a bit, innovativerc will have a brushless chassis for the muggy.
I'm using a prototype right now and Robert is finalising the design.
bdebde
That's All Folks!
bdebde's Avatar
04.30.2009, 03:13 PM
Ebay or losipartshouse
ilpufxit
ilpufxit's Avatar
04.30.2009, 03:43 PM
Thanks guys, I'm tempted to wait for the BL chassis if it's coming soon.
drkdgglr
04.30.2009, 03:49 PM
send him a mail through his shop. might speed things up a bit.
he should be making the 2nd prototype soon. the first was already very good. he was only going to add some lighting pockets. the chassis will work with rc-m's motor mount and battery tray.
riverat1540
riverat1540's Avatar
04.30.2009, 04:14 PM
id definatly be interested in one as well, about what cost for the brushless chassis?
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
  Send a message via Yahoo to riverat1540 Send a message via AIM to riverat1540
drkdgglr
05.01.2009, 02:15 PM
Don't know about pricing. Check his site to see the price for his nitro Muggy chassis. My guess is it won't be far off.
Here's a pic of the new chassis. Tell me what you think. THe chassis is 4mm thick and the spur gear hole is closed, so you'll be limited to a 46t spur. I like it this way because now the chassis has no holes for dirt to come in.
drkdgglr
07.06.2009, 11:26 PM
you can replace the stock steering link with a jato turnbuckle and replace the bushings with bearings.
riverat1540
07.06.2009, 11:28 PM
thanks, i knew it was something like that
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
drkdgglr
07.06.2009, 11:30 PM
not the best pic, but you can see the turnbuckle
riverat1540
07.06.2009, 11:32 PM
cool i get the picture,
Losi Muggy
medusa 36-80-2000kv
6s turnigy 30c
MMMV3
46ts/ 14-16p
spektrum radio
Unsullied_Spy
07.07.2009, 07:04 AM
What does the steering link do? The way I see it the stock aluminum piece will take longer to wear out than the plastic on the Traxxas piece (the metal ball joint will wear out its plastic housing) and the stock one doesn't really have any slop if you tighten it properly and use a little blue loctite on it. The bearings really make a huge difference though, the bushings are fine at first but mine developed quite a bit of slop and I replaced them with some Avids.
The bearings are a 6x10x3 for anyone who's interested.
riverat1540
07.07.2009, 09:51 AM
thanks was wondering that as well, maybe ill just do the bearings first and see how it is as it was tight at one time but sloppy now.
Unsullied_Spy
07.07.2009, 10:08 AM
At one time I had around an inch of play in each wheel. I tightened up the screws holding the tie bar (the piece that he replaced with a turnbuckle) in as well as some other screws in the steering after adding some blue loctite and that straightened it up a lot. It used to be that I couldn't steer it at a standstill, steering would only take up slack in the steering and if I went somewhere it would kinda go where I wanted it to.
