40 series adaptors help please
neweuser
neweuser's Avatar
40 series adaptors help please - 05.20.2006, 10:42 PM
Ok, i know i read up on this in a thread and now can't find it back, can someone help me figure out why i have binding now that i put the adaptors in? I'm sure it's because i have the spacers in wrong so it's stopping the bearings somehow. So if someone can give me a quick answer on how and where to put the spacers in? Location wise? Please??????? Thank you!!!!!!!!! :035:
squeeforever
squeeforever's Avatar
05.20.2006, 11:02 PM
The spacers go inbetween the wheel pin and the bearing. The Prolines tend to stay stuck on the shaft so be careful.
neweuser
neweuser's Avatar
05.21.2006, 12:05 AM
Thank you squee, that's my problem! i got them between the pin to the bearing, AND betweent the shaft and the bearing on the otherside! DUH, i remember reading that! they came with four, so all four should go between the pin and bearing? or the amount needed for a "good" fit but not too tight right? THANKS A MILLION! Yes, they are the prolines! should have gottne the DACE! Oh well, they will work!
squeeforever
05.21.2006, 12:37 AM
Yes, just use as many as needed. Just don't use to many. There should be a SMALL bit of play. Just enough so it doesn't bind.
neweuser
neweuser's Avatar
05.21.2006, 12:46 AM
That's what i meant by "good"...thanks squee, you made my evening!
squeeforever
05.21.2006, 01:22 AM
No problem man!
coolhandcountry
coolhandcountry's Avatar
05.21.2006, 09:26 AM
I think that is the problem. It is not really the location you have the spacers in but how many you have. I ran like 2 a axle on mine. that seemed to work great.
Peace!
Country
Help support the
Rc-Monster
Buy here
