EVX bad? I thought it was...
Chaos
EVX bad? I thought it was... - 06.29.2006, 04:07 PM
this is weird, thought I would share it. Awhile back, my Emaxx started acting real crazy, couldn't control throttle at all, as a matter of fact it tore off down the street full speed and ran into the neighbors garage door! WHAM!! Didn't break anything thank goodness but not knowing what was wrong, or about this forum, I started replacing parts.....first radio, replaced stock with JR XS3, fired it up (holding it in my hand--just in case...) and it went crazy again, forward, then crazy hard reverse, then slammed forward again, almost jerked itself right out of my hand before I turned the switch off. So I tried it with the transmitter turned off, same thing (shoulda done that first, but hey I needed a better radio anyway right!). So, after getting over being mad about that, I put a new EVX in it and sure enough, everything worked fine! Now, the problem I have is I went to mess with this bad EVX today and it is working fine! All I did was take the guts out and clean it all up, then thought I would plug it in and see what happened, had to reprogram it but it seems to work normally now, tested it for about 5 mins with titans on the bench, what do you think?
2 FAST 4 U
NOS Throttle in a Bottle
2 FAST 4 U's Avatar
06.29.2006, 05:29 PM
your speed control may have gotten some moisture in it my speed control on my evaider st did the same thing once.
It's not a monster truck til it has a big block
Chaos
06.29.2006, 05:36 PM
well that would be nice if that is all it was, thing is, I am affraid to sell it not knowing for sure but I don't need it either!! lol, but I could use the cash for other things, I'm sure you are can see my dilema...lol. Anyone need a EVX that tested good? lol
