Spinning hexs out of control -
07.14.2006, 08:44 PM
Im rounding out rear wheel hex hubs like crazy. Ive ruined one wheel and Im on the way to ruining the second. Im using lock tight and all too. Problem is if I really muscle the wheel nut my wheels dont spin freely.
I know the answer is those 23mm adapters. Are the prolines any good or is Dace the only choice?
I guess the ultimate solution is aluminum 14mm hex hubs and the Dace 23mm adapters. Then Im buying all new wheels and tires :035:
I dont read about this issue much and Im wondering why its happening so often.
When using an overpowered system the hex will get forced in both directions (clockwise/counterclockwise). The combination of accelerating and braking will stress the plastic adapter and wheel hex. The slack will exponentailly increase because of the power and then it will strip out.
So, to stop all slack from happening you should JB weld the hex in the wheel.
The aluminum hexes help out. A set of aluminum rims won't strip either.
I like the 23mm hexes the best. Dace is the best. I have a set proline and have the pin turn 90 degrees inside the hex.
Rc-Monster Buy here
