Lowered Centre Of Gravity and Traction
Darren
Lowered Centre Of Gravity and Traction - 07.01.2006, 03:34 PM
Just bought myself a G2 for my E-Maxx, can't wait for it to arrive!
Anywho, I was wondering, would a lower Centre Of Gravity chassis like the G2, help me with traction on my track? Our track has some parts where I am just constantly wheel-spinning and I have been told, and have figured that the Maxx is too light, however, having all that weight slung much lower, will this help me? I'm a little confused either way. I can think of why it could help and why it couldn't.
I know that It will help me to no end on corners when I use my stock maxx tyres, which i'm rather fond of. I also know it will stop my maxx from wheely-ing as much (well a tiny tiny bit :018: )
coolhandcountry
coolhandcountry's Avatar
07.01.2006, 03:39 PM
The gmaxx helps on wheeling. Have you tried a set of mulchers if the track is kind of loose. The seem to grip well. they got the new 40series out to.
Darren
07.01.2006, 04:07 PM
I find mulchers not that great, of all my tyres, mashers are pretty good, only slightly bettered by the stock maxx tyres. Here is the track.
Here are the bad areas for wheelspin:
Mostly the mud/loose parts of the track, but I do get it on the grass and occasionaly on the astro.
crazyjr
crazyjr's Avatar
07.01.2006, 10:46 PM
It might cost you some traction, with the weight sitting low it can't move as well (weight transfer/ rocking back and forth) so it might lose some traction. On the other hand with less weight transfer, more weight will be on the front wheels, therefore it might get more tire surface on the track and increase traction. I can't tell you by experience, because the track i run on is sandy and the best way to drive is drifting
squeeforever
squeeforever's Avatar
07.01.2006, 10:58 PM
Just an idea here, especially since I don't know your track particularly, but you could also try a different like. It appears as though your having trouble were the typical line is. Try something like the line in purple. The black appears to be the usual line people run. However, if you carry more speed into that first turn in the picture and go wide then on the inside, you might have an edge since you would have more traction and be able to carry more speed.
Darren
07.02.2006, 06:10 AM
Thanks squee, i'll give it a go. Since the gorillamaxx lowers the centre of gravity, I wont be so prone to rollover using my maxx tyres, hence, more corner speed, so I might get away with it.
I only race against 3 stock savages, an MTA4 and a slightly modded LST anyway. The maxx in stock setup with 9XL has won me a medal against them, can't wait to see how amazing it's gonna be with the G2.
Did you use paint aswell then :) ?
squeeforever
07.02.2006, 11:22 AM
:018: Yup, the G2 should help considerable. And yes, thats paint :028:
HotnCold
HotnCold's Avatar
07.02.2006, 06:54 PM
You should be careful when racing against them now - you spank them too bad - and youll be racing by yourself - LOL - That chassis is a huge improvement - post back and tell us if you agree... Good racing...
Hows that "Hope and Change" working out for Ya???
phidailo
07.03.2006, 01:05 AM
You will love the chassis and it can take a beating
  Send a message via AIM to phidailo
Mike.L
Mike.L's Avatar
07.07.2006, 10:15 AM
lol to me thats a bunch of scribbles:005:
thats a big track darren why wont you try some bow tie (Mt). there pirtty good getting me a piar soon
  Send a message via MSN to Mike.L
CCristo
07.03.2006, 10:33 AM
Have you looked int other chevron type tires? The Imex Trail Dawgs are a similar tread pattern, but are much softer than the Maxx tires. You could aslo try modifying the tread on the stock tires to increase traction. Start by slicing every other rib so that they are more flexible. If that doesn't work, try cutting every other rib so that look more like knobbies.
Darren
07.03.2006, 12:08 PM
Well I like how the Maxx tyres handle, minus the traction part.
I got my G2 this morning :eek: I bought it at midnight on thursday!!!!! Un-believeable service Mike.
I'm going to leave the setup as it is but lower the ride height a little. Hopefully this combined with the G2 should stop all the wheelspin. I'm also gonna buy an 18t pinion (16t currently), as it is very very front happy, so it wont accelerate quite as fast. I also put the 7 cells into the rear 7 slots and moved my receiver and hump pack to the rear, hopefully this should all help.
Anyway, i'll let you al know how it goes once I get the maxx running again. Had a wipe-out and took out the stock chassis, a skid plate, steering rach and a set of bulkheads, good excuse to get a free G2, huh? :018:
Hotncold - I agree, at the last rampage (official race days with medals and stuff) I won the MT A Final' by 45 seconds (a lap is about 34 seconds).
Squee - Paint rocks :027: !
CCristo - I was considering cutting lines in the edges of the tyres like this:
I'm not sure if that would help alot, maybe cutting the lines further in?
If that fails, CCristo I will get me some imex trail dawgs :) .
squeeforever
07.03.2006, 12:39 PM
I wouldn't ge the trail dawgs. I have NEVER heard anything good about Imex tires. I would go for the new Traxxas 3.8" Chevrons. They should help a little because of less sidewall flex and the sides of the chevrons aren't so tall. http://www.traxxas.com/products/nitr...ccessories.htm
BP-Revo
BMW M Power!
BP-Revo's Avatar
07.03.2006, 04:53 PM
What about sporttraxx tires...
My CF MT's hook up on grass rather well once you get going and the Sporttraxx's have taller and more spread out knobs so they should be even better in grass.
Also, the taller and more spread out knobs should really help in the loose stuff...
I have been kinda eying this thread and the Sporttraxx idea just smacked me in the head...
Also, from what I heard, the Sporttraxx's are supposed to be good all around...
coolhandcountry
07.03.2006, 05:25 PM
The mulchers get much more traction that the sport traxx. IMO
