SDP-SI Module 1.0 SS Pinions
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
SDP-SI Module 1.0 SS Pinions - 09.30.2007, 09:22 PM
I bought some SS Mod 1 pinions last week and got them in the mail today. Is it just me, or do they have a REALLY SMALL set screw in them? I don't even have an allen key small enough! I might try and drill them out and tap it for a 4-40 set screw; or do you think grinding a flat in the motor shaft will be enough? I know some of you have bought these pinions before. Have you had any trouble with them spinning on the shaft? Seriously, who thought it was a good idea to use a 1.5mm (diameter) set screw in a Mod 1 gear? Does anyone even make a 0.5mm allen key?
What's_nitro?
10.16.2007, 08:42 PM
Thoughts, anyone?
10.16.2007, 08:44 PM
Yeah, I think it'll be fine as long as you have that flat spot. The only downside to smaller grub screws IMO is that the hex driver to loosen/tighten them is smaller and may tend to strip out easier if you use red lock-tite or really torque down on the grub screw.
What's_nitro?
10.16.2007, 08:48 PM
Thanks for the reply, Brian. I'm definitely gonna use some thread-locker. Do you know what size set screw Mike uses in his Mod 1 gears? I would really prefer to have some with a larger screw because I am afraid I'll strip these and/or just break the allen key (once I find one to fit).
BP-Revo
BMW M Power!
BP-Revo's Avatar
10.16.2007, 08:57 PM
I would just drill it out and re-tap if you can...really not worth it to use a micro sized set screw when the whole point of having Mod1 pinions is to hold up to the power...
What's_nitro?
10.16.2007, 09:02 PM
Originally Posted by BP-Revo View Post
...the whole point of having Mod1 pinions is to hold up to the power...
You took 'em right out of my mouth. I'd like them back...
3mm sounds much better, Brian. I'll have to pick up a few from RC-M. They really couldn't be worse, ya know?
10.16.2007, 08:58 PM
IIRC, the ones I have from Mike use 3mm hex wrenches...
gixxer
gixxer's Avatar
10.16.2007, 09:35 PM
I could be wrong but I thought they were 2mm.
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
10.16.2007, 10:01 PM
Hmm, well, they're either 2.5mm or 3mm since those are the only wrenches I have.
squeeforever
squeeforever's Avatar
10.16.2007, 09:21 PM
Yup, Brians right. There 3mm.
Patrick
Patrick's Avatar
10.16.2007, 10:49 PM
Mine use 2mm hex, and some of my smaller ones (before he went to all hardened gears) use a 1.5mm hex.
gixxer
gixxer's Avatar
10.17.2007, 12:21 AM
thats what I thought.
AAngel
10.16.2007, 11:00 PM
Can you drill and tap stainless steel gears? Most stainless that I've run across is pretty brittle.
Patrick
Patrick's Avatar
10.17.2007, 12:29 AM
Just rechecked my pinions. My older ones (the silver non hardened ones) that are 15t and under have a 3mm grub screw with a 1.5mm hex.
My carbon steel 16t and 20t pinions use a 4mm grub screw with a 2mm hex.
And the newer hardened steel ones which I received yesterday also have a 4mm screw with a 2mm hex. Mine are 17t and up, so I'm not sure if the smaller ones use a 4mm or a 3mm.
MetalMan
MetalMan's Avatar
10.17.2007, 01:14 AM
I have a couple 20t mod1 5mm bore pinions from Mike, the most recent one being from maybe 4-5 months ago. Both use 4mm set screws, which are driven by a 2mm hex driver.
