video 3s hvmaxx 4.5 motor and mm -
11.02.2007, 09:11 PM
here it is , ill try to get a better one tommorow, very little cogging, temps were good batt. and esc got the warmest, motor cold
when i came in i after 10 min temps were 80 battery, 85 esc, 75 motor ( around 50*f outside)
What esc did you use, MM? It does perform extremely well in lighter vehicles, so in theory the 6.5 motor would be a bit tamer, but still really fast & torquey.
it works , but must be in a light truck(?)
the 6.5 would be better, one of the wheel nuts kept coming loose, tires looked like doughnuts, but i have not tested on 2s which would be better if it works, the mm does not have the software to run but it seems good in this lighter truck
