LVC for Lipo
rcjmaxx
LVC for Lipo - 07.27.2005, 04:29 PM
I am getting very serious about going lipo in my brushless Emaxx but am having trouble finding some type of low voltage cutoff.It seems a few of you are using lipo in your rides,how are you dealing with the threat of over-discharging these expensive packs? Thanks in advance.
El Jarretto
07.27.2005, 04:55 PM
Some controllers come with 3V cut off.(Like MGM's) With the Warriors you have to get a programming cable but I've heard the cut off voltage is a lttle low and some find it unsafe. Maxamps has a low voltage detector that you solder onto the wires of your esc. Although all I kinow is it uses LED's, it needs to be a little more discriptive.
Gustav
Gustav's Avatar
07.27.2005, 08:15 PM
What about this?http://www.battsignal.com/
MetalMan
MetalMan's Avatar
07.27.2005, 09:13 PM
There is another product out there called Lisaver. It pulses the motor, which is more noticable that the buzzer sound or an LED. I know since I made my own LVC device with a buzzer. Here is a link to the Lisaver:
http://www.flydma.com/lithium/lithium.asp?path1=lithium
