E-Revo with tekno-RC and Neu 1515/1y
mabu
E-Revo with tekno-RC and Neu 1515/1y - 01.07.2008, 02:27 PM
Hi,
i finished a few weeks ago my revo conversion using the tenkorc kit.
i used a neu 1515/1y in combination with a quark monster pro 125b.
the first runs were done with 4s Kokam H5 3200 Lipos - but with these Lipos i ran only about 10 min and had amp spikes till 70A.
I was able to do wheelies with this setup ( with installed cd ) if the slipper was closed.
eagletree data from the last run:
I was told that the lipos will get killed with these spikes over 20C
And that the minimal voltage is about 13.12V - which i find not ok :(
So i am looking for some new lipos - which would you recommend?
I also want to use them in series ( as 8s setup ) in my emaxx, which i gonna rebuild this year ...
david lamontagn
01.07.2008, 03:03 PM
Flightpower EVO25 and now the EVO30 was somes killers batts.
electric
electric's Avatar
01.08.2008, 09:15 AM
what speed do get and runtime. What voltage is the batt you are using and would a 18.5v be to high for the MM.
thanks
david lamontagn
01.08.2008, 10:05 AM
thanks
Yes 18.5volts is realy to high for the MM ocntroler. The EVO25 can be purchased at RcMonster Store.
I use 14.8 volts EVO25, 5000mAh pack, and i can't tell you about run time, i don't ave the time to drain all this batt before winter. The day that my revo will be ready, lot of snow has fall outdoor, so i've to wait next summer for real test.
electric
electric's Avatar
01.07.2008, 10:01 PM
where can i purchase those evo25 and evo30 batts
BlackedOutREVO
01.07.2008, 11:10 PM
Tower hobbies...
http://www2.towerhobbies.com/cgi-bin...SM&C=ANC&V=FPW
YogyBrushless
01.10.2008, 03:58 PM
hey guys, if u want hyperion 20c batteries try allerc.com they have some good deals in the clearance section (page 2) , i picked up a 4800mAh 5S 20c for 140$.
yOusef
raptor50
01.17.2008, 01:37 AM
how do you like ur hyperion 5s 4800? Im thinking of getting this but not sure of the brand.. how does it compare to flight pwr or thunder pwr
