How do you define a Monster Truck?
Nic Case
Fast RC-Monster
Nic Case's Avatar
How do you define a Monster Truck? - 07.31.2008, 09:57 AM
With the advent of the Truggy ----- Where is the line between MT & Truggy?
I'm confident, you guy's will know.
BTW-- a picture is worth a thousand words..............
N
bl-is-future
bl-is-future's Avatar
07.31.2008, 10:17 AM
IMO if it has a high center of gravity and has big wheels it is a MT. If it has a low center of gravity and big wheels it is a truggy. If it has a low center of gravity and small skinny wheels it is a buggy.
That is a very broad way to explain it but that is what i look at.
brushlessboy16
brushlessboy16's Avatar
i think truggys are different because they run 3 diff setup and wing mounts like buggys and mts usually run a transmission, no wing and have higher ground clearence...
dont hold me to it though :D
07.31.2008, 10:18 AM
Stretched Buggy = Tripple diff = Truggy
Transmission = MT
bl-is-future
07.31.2008, 10:19 AM
Transmission = MT
but you can mod a MT with a center diff and it still looks like a MT and handle like a MT. I see the point though just wondering myself now?
07.31.2008, 10:23 AM
This is very subjective to nic's point - I'd hardly call a revo a MT once you've got it set low, running LPRs, sway bars, centre diff and a wing..
wallot
wallot's Avatar
07.31.2008, 10:25 AM
you can mod any vehicle to look differently. you need to take in account just stock vehicles.
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
brushlessboy16
hmmm
good point, but without the wing and center diff it would be an MT
07.31.2008, 10:29 AM
I think Nic's asking this in relation to the speed challenge - Any hence a revo with zero ground clearance on foams - Is it still a MT?
bl-is-future
07.31.2008, 10:51 AM
that is correct... It is so broad on how to classify a vehicle. Stock is pretty easy to determine but who honestly keeps the RC stock no days. Then you have on-raod cars that use transmissions. IMO it is more the physical layout and handling of the vehicle rather than the drive train. ex it looks like a MT with the big wheels and truck body but it handles like a on-raod racer because it is so low. That i would call more of a truggy now but put a buggy body on it then what is it? basically this applies Buggy + Truck = Truggy. IMO a truggy handles real well but looks good and get through some rough terrain. A buggy handles beautiful but is limited to terrain. MT is almost never limited by terrain but handles like crap for racing. but either one of these you can mod to handle like another. You can file things down add longer shocks to a buggy and it will handle like a MT. Or vice versa.
07.31.2008, 10:57 AM
For speed challenges, I would set specific requirements for each based on ground clearance, weight, and body style.
TexasSP
Something, anything, nothing
TexasSP's Avatar
07.31.2008, 11:27 AM
These should be the base rules in my opinion. I also think there should be a freestyle competition where anything goes though.
MT:
High ground clearance
6" or larger tires/No foams
Chassis built above diffs
Transmission
Truck or SUV body
No Sway bars
No wing
Minimum 12" Wheelbase
Truggy:
Chassis below diffs
5.5" or larger tires/foams acceptable
Center Diff/No tranny
Lower ground clearance
Truck or SUV body
Wings acceptable
Sway bars acceptable
www.cubicle101.com
brushlessboy16
07.31.2008, 12:08 PM
MT:
Transmission
Truck or SUV body
No Sway bars
No wing
Truggy:
Chassis below diffs
Truck or SUV body
Wings acceptable
what about tvp trucks?
notnodak
07.31.2008, 12:25 PM
Just remember the T-Maxx series has 5.75" tires except the newest T-Maxx
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.31.2008, 01:30 PM
MT:
Transmission
Truck or SUV body
No Sway bars
No wing
Truggy:
Chassis below diffs
Truck or SUV body
Wings acceptable
I like this idea.. but maybe add/modify
M/T
Tire height should be 5.75"+ no foam
Tire width should be 3.8" + no foam
Tires has to outside of the body and fully exposed.
Chassis built above diffs and/or TVP
Has a Tranny (or center diff built inside a tranny or built above/higher than the front & rear diffs)
Truck, Jeep, Semi or SUV body
NO Sway bars
NO Wing
Minumum 13"+ wheel base.
TRUGGY
- rules looks pretty good to me..
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
