cut a flat spot in shaft for the pinion set screw?
auto2
cut a flat spot in shaft for the pinion set screw? - 04.10.2008, 07:04 AM
i didnt make a flat spot on my neu 1515 and seems to be working. am I supposed to ?
Happywing
04.10.2008, 07:18 AM
No, but I would.
auto2
04.10.2008, 07:23 AM
i see some of the NEU NEU motors have a flat on them? makes me think it is needed.
running on a dirt track so not much traction .
83gt
04.10.2008, 07:41 AM
It's not completely necessary, and usually some locktite on the grubscrew will suffice. If it ever starts to slip, use a dremel or file to make a flat spot for the grub screw.
J.
04.10.2008, 07:54 AM
I agree - I would start with no but be prepared to...
That was my route...
bl-is-future
bl-is-future's Avatar
04.10.2008, 08:24 AM
I agree with all the above.
crazyjr
crazyjr's Avatar
04.10.2008, 10:54 AM
If works fine, good, you don't have to yet. But as others said, you may need to later. Me personally, I start with the flat spot
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.10.2008, 10:57 AM
My Neu came with a flat on the shaft but I usually make one anyways. Some say it isn't necessary but I'd rather just do it and KNOW I wont have a problem down the road.
04.10.2008, 10:59 AM
I must be doing something wrong then because even with blue lock-tite on the screw and torqueing it down (and I'm not a weak guy), the pinion started to slip in about 10 minutes. This was on a steel spur/hardened pinion setup so that may have something to do with it.
I would just grind the flat spot. It won't hurt anything to do it, and will prevent you from having to unmount it again later if you decide you need it.
Rcaddict
04.10.2008, 11:05 AM
If you're planning on racing, I would do it. You would hate to lose a race because of the pinion slipping or coming loose. I just put one on my new NEU last night. It had a flat spot already but wan't where I needed it.
bl-is-future
04.10.2008, 11:11 AM
I like it when the motors don't come with a flat spot so i can make on myself. That way i know it is not to big and is exactly where i need it. The more flat spots the weaker the shaft.
Happywing
04.10.2008, 02:49 PM
I agree. I like a nice quaint little flat spot. When the manufacturers do it, it seems they lop of 20% of the shaft.
azjc
04.10.2008, 03:20 PM
With my 9L on a rustler I have the opposite problem, I can't get the pinion off, but unless I fry the motor I don't see a need to remove it, if anybody has any secrets I am all ears.....
04.10.2008, 03:53 PM
pinion puller...
neweuser
neweuser's Avatar
04.10.2008, 04:04 PM
Heat just the pinion up a bit, it'll come off. Either that, or use a small gear puller
