15 - Relates to the rotor diameter. (in MM?)
09/12/15 - Relates to the rotor or motor length. Larger numbers means a longer motor.
1.5/1/2.5 - The number of turns
d/y - The coil configuration: d=delta/triangle. y=wye/star
f/s - f=finned can. s=smooth can (which can sometimes just be nothing)
You will have to run a mod 1 pinion
http://www.rc-monster.com/proddetail...1pinion&cat=40
I am running 37 000rpm in my 8ight. If you are looking at running 22v I would look around the 1500kv motors
