Lightning Stadium Pro - R conversion questions
SunnyHouTX
SunnyHouTX's Avatar
Lightning Stadium Pro - R conversion questions - 06.02.2008, 01:07 PM
Hey there guys,
I've just dipped into this conversion with the following:
*Feigao 7XL geared 14/49 (Mod1) with L size clamp/heatsink and fan
*Hyperion 5S 5350mAH (plugged into newer MM at about 20.76V)
*MM ESC with fan (while I wait or my MMM from RC-Monster)
*CC BEC
*MG995 servos
*Mechanical brakes with brakes on MM set at 10% and no drag brakes
*MM set at 50% punch control, lowest motor timing, 16.5V LVC and high start power
Here's the data from a couple of runs:
After about another 10 or so quick full throttle passes, motor temps were about 130*F - 140*F, ESC at 115*F and Lipo was under 100*F.
Ambients were around 90*F last night when I ran.
I think that this is a good set-up till the MMM gets here because the current was decent. What do you guys think? Should I be worried about something?
Thanks for any and all input.
Edit: changed the motor from 6XL to 7XL because that's what's in there. My E-Maxx has the 6XL
