MM ESC will not go into reverse and I have no brakes -
07.02.2008, 09:12 PM
Any ideas how to fix this? I was running ch. 3 w/mech. brakes, disconnected servo from rx, and wanted to try esc brakes, nothing, not so much as any drag brakes.
07.02.2008, 09:17 PM
Stupid questions, but:
1) Are you running a 2 speed tranny? They typically use a OWB on first gear rendering motor brake and reverse impossible.
2) Did you hook your MM to the Castle Link and make sure brake and reverse were enabled?
07.02.2008, 09:19 PM
yeah seems like a one way bearing...
07.02.2008, 09:20 PM
No on the two speed , in a 1/8 buggy and I programmed it w/the castle link. The esc seems to be getting the info, but nothing is happening...should there be a red light on when reverse is engaged? On my mamba 25 the red led indicates rev...
07.02.2008, 09:21 PM
Might have to recalibrate the ESC to the radio. Maybe the ESC doesn't "know" where reverse is...
07.02.2008, 09:24 PM
Thanks Brian, I will try to recalibrate and see what happens.
07.02.2008, 09:38 PM
I tried to re cal. While the red led is flashing and I hold trigger in rev. direction, the yellow light will not flash (after a few seconds.) nor do i get the tones. I tried several times with no luck. the red led just keeps flashing.
07.02.2008, 10:06 PM
Well, finally got it to work, but, when in reverse, it glitches and is not smooth. At least for now, I have brakes. I suspect that something in my programing of my radio is preventing the smooth reverse.
07.02.2008, 10:23 PM
Check to make sure that your endpoints are set to 100% for both forward and reverse when you calibrate the MM - even if you drop it down later that's the only way it will calibrate properly.
“Everyone has a right to be stupid; some people just abuse the privilege.”
07.03.2008, 08:54 AM
Thanks Vintage, I forgot all about that
