As recorded from the EagleTree Car Data Recorder, here is the setup:
Associated MGT with the following:
TRC Paqman pre-mounted tires
OFNA Center diff (51t nylon spur)
Feigao 10L motor (12T pinion)
MGM 12012 speed controller (old style)
FMA/Kokam 3s2p 6400 mah 20C lipo cells (two 3s 3200 packs in parallel)
Nomadio Sensor radio system
BlueBird BMS 620MG servo
The data is from bench testing only, since I just got the EagleTree recorder hooked up.
I only set up for and recorded battery voltage, amps, watts, and throttle movement.
The first graph is all of the stats at once, which comes out confusing. The following graphs show each stat alone.
I'm hoping to record some practice runs at the track tomorrow night.
I will also bench test with the following changes in the next few days:
Batteries
4s2p 6400 lipo
12-cell GP3300
12-cell IB3600
Gears
15T pinion
16T pinion
If I get the time I'll also do all the same with a Feigao 8L motor in the same setup.
Here are the graphs:
http://i20.photobucket.com/albums/b2...BenchTest1.jpg
