Interesting Project Idea...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
Interesting Project Idea... - 08.10.2008, 01:20 AM
I was thinking () that this would make a sweet project. Something worth saving up for, and then, putting the time into anyways.
http://www.military-today.com/apc/stryker.htm
I want to buy two Ofna GTP kits and hack 'em up in order to put both steerable axles up front and the other two axles in back. I'd have a low kV outrunner bolted to each of the four diffs via a CV joint. 8s LiPo sounds like a good starting point, with CC HV45 controllers for each motor, and two Hitec 5955TG servos for the two steerable axles.
I found out recently that the HV110 controllers are capable of motor-braking with cars/trucks, so I'll use the motor brakes with the HV45's. It's an assumption, I know, but a reasonable one. Unless someone out there knows otherwise.
The body will be made from 0.125" polycarbonate and I'll have it bolted directly to the chassis. Color scheme? I was thinking black.
Last edited by What's_nitro?; 08.10.2008 at 08:44 PM. Reason: I can't speel when I'm tired. :)
TruckBasher
TruckBasher's Avatar
08.10.2008, 03:26 AM
It really is an interesting idea. I am also thinking of making something like this but a similar setup to those battlebots..but it never materialized
Hope to see your result on this....
E-Slayer direct drive to diff
J3110
08.10.2008, 05:31 AM
Sounds interesting.
If you need a better ESC, many of the battlebots guys use Vantec speed controllers:
http://www.vantec.com/rdfr.htm
I'd go for the RDFR47E: "Heavyweights, 3HP Acrobatic Go-Cart"
Worked fine for pushing 325lbs around on metal plate conveyor belt tracks:
It might be overkill, but these things most likely won't fail on you like some of the other "100a +" ESC models have been.
What's_nitro?
08.10.2008, 08:49 PM
Truckbasher: Right now it's only an idea. I could probably build the entire thing for less than $1500, but that's still a lot of cash. If I find a deal on the two Ofna GTP kits then we will see some progress.
J3110: Those controllers look nice, but they're a bit too pricey for me. They're also more ESC than I'll need. I've been meaning to drop into my highschool and see if they still participated in the Battlebots competitions...
