RC-Monster Xray XB808 mount pictures -
09.19.2008, 11:14 PM
Hey guys. Just thought I'd share a few photos of Mikes latest creation. Its a new mount for the Xray XB808. Its got a new feature on it that is a first for the electric motor mounts. It is a 2 piece mount that makes the dif accessible from the top for easy maintenance and tuning.
Here are a few pictures. I ran this prototype version last week and was perfect. It wont be available in the store for a few weeks, but its comming soon. I hope he eventualy gets around to updating all of the mounts with this 2 piece desing. Its like a factory piece. Nice work Mike.
Just thought I'd share. Heres some pics.
to make it...
or break it...
wow that is sweet i hope he makes the rc8 mounts like that i went to switch diff fluid today and removed the top plate and then realized it all has to come out
I am loving that design. If only he came out with these nice innovations earlier. Well hopefully by my next conversion, all the mounts will be like this.
Wow! I think this is the first time for him to cut a motor mount out of a 7075 grade aluminum. It'll be a bit expensive that way, but stronger for sure.
Nice to meet you!
Looks very nice indeed! Jeff, can you tell if the mount is spaced such that you could fit mechanical brakes without a spacer (when using smaller pinions)?
No. You would still need the motor spacer if you want to run small pinions with the mechanical brake disks. Its no different from any of the other motor mounts in that regard. But the spacer Mike sells works perfectly. I have been running it for a long time on my truggy and its perfect.
to make it...
or break it...
That design is perfect....easy access to diff. changing gears,etc...
