Converting SC8. 2200 or 2650 combo on 4s?
Dragonfueled
Nore more bump boxes and after run oil
Converting SC8. 2200 or 2650 combo on 4s? - 02.01.2009, 01:33 PM
Ive been running my e revo on 4s with the 2200 and its awesome. Im gonna do a Associated SC8 conversion and im not sure what combo to use. It will also be a 4s setup but do I need the extra rpms cause of the small tires? Im looking to be in the 35 to 40 mph area with decent temps..
Brushless ..... I put that s... In everything.
02.01.2009, 01:44 PM
It is basically a buggy the 2650 will be fine but so will the 2200 is you gear up a bit...
I'd go with the 2200...
TexasSP
Something, anything, nothing
TexasSP's Avatar
02.01.2009, 02:13 PM
The 2200 gives you more wiggle room and better options. It would be my choice as well.
www.cubicle101.com
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.01.2009, 06:01 PM
Since you already have the 2200, it doesn't hurt to try it in a buggy, but you will also get good results with the 2650.
Area 52 Ranch Raceway
T.R.C.R.
nik77356
02.01.2009, 06:18 PM
The SC8 is just as heavy or heavier than a truggy because of the roll cage and body so I would go with a 2200 combo.
02.01.2009, 06:25 PM
I vote the 2200 as well. It may be a tad large for a buggy, but will stay cooler due to the extra surface area. Geared for the same speed, either will produce around the same power.
02.01.2009, 06:49 PM
Well now everyone is coping me I say try a medusa 50mm on 5s...
Dragonfueled
02.01.2009, 07:13 PM
Cool thanks guys I ordered the 2200 now I just need the sc8 LOL
