Battery Idea
azjc
Battery Idea - 02.24.2009, 09:50 PM
I have heard some of the guys that race buggies and truggies complain about the hassle of changing batteries in a timely manner using the Losi 8 battery holders with the 3 velcro straps. I dont use straps for my batteries but I lay a strip of female velco in the bottom of the battery tray and use a strip of male velco on the bottom of the pack. It holds well for me and less work to change batteries. The only negative I have thought of is down the road the velcro might wear out but so far so good
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
02.25.2009, 02:08 AM
Surely the batteries could be ejected in a big crash.
02.25.2009, 02:44 AM
Some sort of positive hold down is a good idea. The repeated use of large amounts of velcro will most likely distort the pack, and without a strap wrapped around the pack cell shifting becomes a big concern. Hardcase lipos are a good idea for this, but I have seen the interior construction of the losi hardcase, and am not impressed at all. No padding and the cells are just floating free in there.
I would like to see a properly designed hardcase style battery box that has 4 locating pegs, one at each corner. Fixed male bullet connectors could be mounted to a plate on the chassis pointing upwards, with female connectors on the hardcase, facing downwards, like a trakpower pack upsidedown. An over center latch would hold the pack in place, and also have a lift up device built in to release the pack when the latch was disengaged. The four corner peg design would hold the pack front to back and side to side, and the latch would keep it from coming off the pegs. The peg desing takes the load off the latch and aligns the bullet connectors perfectly everytime. 5 sec battery swaps with this setup, no problem.
I need to whip up a prototype, most likely with wood blocks to show how it would work...
shizzon
shizzon's Avatar
02.25.2009, 02:59 AM
the best option i could see is a battery and mount that are made for each other.... I see a hardcase lipo in which the protective shell itself is part of the holding mechanism. So latches are located on the chassis itself and the battery "clips" into the latches. If you wanted to you could even have the battery leads be located at the latch so that when you latch the battery it is automatically connected to the esc, no wires or other connections needed. obviously this would be a quick release system, and there is more that needs to be thought about but i think the general idea is good.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
shizzon
shizzon's Avatar
02.25.2009, 09:40 PM
here is what i have some up with for a solution for an 1/8 scale quick release battery tray. It is actually a system that includes the battery and the tray, this way the connections are made when you snap the battery in rather than having to plug in a deans etc. This is the first version, and im sure there are improvements that can be made, but it seems like a possible idea to quicken the time it takes to swap packs.
take a look, tell me what you think. ill post some closeups to the latching mechaninism later tonight.
[IMG][/IMG]
As you can see the battery leads are incorporated into the latch itself, and the rear of the battery is held in place by the slot on the backside of the battery.
I have sketches that clarify the latch, ill post them later.
Toys:
Slash with VXL
Metallover
RC-Monster Spudgunner
Metallover's Avatar
02.25.2009, 10:48 PM
I thnk some kind of nested box would be nice. Just a regular battery tray with foam all around with a latching lid with foam on the bottom. That would be nice. Not as good as a hardcase latching idea, but close. Something like da shizzes disign would work great. You know what, I'm going to go into my shop and.....
02.25.2009, 11:26 PM
What about a tension band....I saw a mmm esc w/ a tension band around it. You could do the same for the battery...just have a loop on an end so all you have to do is remove only one end while the other end could be fixed...I probably didn't explain it well, but, I can picture it in my head!
shizzon
shizzon's Avatar
02.25.2009, 11:33 PM
something like this?
[IMG][/IMG]
just another of my ideas, this is the second version of the design using brass angle iron.
Toys:
Slash with VXL
02.26.2009, 12:09 AM
Yup! exactly like that...just use your concept for the batts...that way it is quick and easy!
shizzon
shizzon's Avatar
02.26.2009, 12:18 AM
but that would be to easy, and particularly like the idea of not having to connect the battery leads to the esc. Its all one step, when you latch the battery in you connect it to the esc.
Obviously this isn't something that most will have the capability to do... I was aiming mores so towards larger manufacturers who have the capability to produce these systems on a large scale. Who knows, maybe Mike or teckno will PM me for a business proposition, that would be nice lol:) there are definitely easier ways to strap a battery to the chassis, but i believe that this alternative will give an edge to those who are racing.
Toys:
Slash with VXL
Matthew_Armeni
Matthew_Armeni's Avatar
02.26.2009, 05:25 PM
Obviously this isn't something that most will have the capability to do... I was aiming mores so towards larger manufacturers who have the capability to produce these systems on a large scale. Who knows, maybe Mike or tekno will PM me for a business proposition, that would be nice lol:) there are definitely easier ways to strap a battery to the chassis, but i believe that this alternative will give an edge to those who are racing.
Your design is very similar to something I was throwing around, and it would work great. But there is one problem, it requires a specific battery. Right now it's hard to make a true quick change battery/battery mount because there are so many different sizes and setups out there. If everyone were running the same batteries and connectors then maybe it could be done. Until then we need to have universal battery mounts/trays instead, and straps are the simplest and strongest solution right now.
I also would like to say that I don't think we really need a quick change mounting system. Yes, I realize some people run 20min mains but they are really in the minority. Most clubs do 15 min. 15 min can now be done on one pack and I personally don't want any race, nitro or electric, longer than that. I especially don't want to marshall any longer than that. Once enough people get on the brushless bandwagon most tracks should have a separate class. Then we won't have to worry about stop and gos, and pushing our electronics to run non-stop for 20 mins, etc. Once summer gets here, I think we may hear about more people frying their gear, pushing it too far, and potentially scaring off newcomers to the large scale brushless scene. This is just my opinion, and I didn't mean to rant on your thread.
  Send a message via AIM to Matthew_Armeni
02.26.2009, 06:10 PM
Some great ideas, and valid points raised- some of you guys are mind readers I swear.
Industry standard connectors and lipo sizes are some way off really, but on an individual/personal basis, single users could make a system that works for them, laying the foundations for designs from larger corporate bodies- think RCM BL conversion motor mounts > manufacturers releasing their own electric vehicles (even though Mike's tend to be better designed and thought out ).
