wouldn't it be cheaper to buy a lighter and paper?? and roast hot dogs over the top of that?? you never know whats in those lipos ether, you might end up with green weenies
There are some weird "tricks" floating around with Lipos...
My boss races RC oval (Nascar style) and he along with his racing buddies claim that a Lipo charged at about 120deg. F will perform better when run (you let it cool down before using it). I just dunno anymore.
Isn't 140* a bit too hot??? I mean the safe limit is like 160* right? Pretty much all battary types perform better when they are warm (electrons can move around easier), so the idea behind the product is correct. Their marketing scheme is ridiculous though. Using the word "Pro" in front of any product usuall turns me off of it, because it usually isn't. It's supposed to make you think it's high quality and/or worth the high price they charge for what amounts to a coil of wire in a bag. On top of that, the ad claims you get higher voltage from your lipo when you use it. I would like to see proof of that, but I never will- because there isn't any and there never will be.
I'd use that to put my ding a ling in in winter time here in Wisconsin when snow blowing. Nothing worse than a frozen schlong. Other than that I can not think of any other good uses for that.
ok so i am not the only person who is wanting to see some facts on lipo performance charging/discharging at unholy temps on a lipo. 100 sounds better like linc said, right where my 6s neus run. whats next a speed control or motor warmer?
Lipos perfom best when preheated before use at 35 - 40°C. Try it and compare the performance at 20°-25°C. More heat -> faster goes the chemistry... first type of LiIon needed preheating to even higher temperatures to even work.
