Covering up 2200kv Tork breath holes? -
05.21.2009, 12:34 AM
Someone in another forum is stating I should seal up the holes in the front of my Flux Tork motor to keep stuff from getting inside and ruining the motor. I'm under the impression those are designed for air flow for the Tork and sealing them up would be a very good way to overheat my motor.
Whats your take on this Castle?
def mounting holes. you can see the threads in em.
neu motors have huge openings on the ends of the can and most here cover them both up. as long as you gear correctly and monitor temps the first few runs, you will be fine
Thank you Pat, so i'm not slowly destroying my Tork by leaving them open to the air to suck in dust? Their covered up behind by the endbell cover? Sorry, I just don't wanna screw this up, I just want to prolong the life of my Tork motor either way.
i think there is the only question on the savy flux is the location of the motor because donīt get much air to run fresh.... but because is the famous 2200kv mamba one maybe it donīt make any problem!!
Thank you Pat, so i'm not slowly destroying my Tork by leaving them open to the air to suck in dust? Their covered up behind by the endbell cover? Sorry, I just don't wanna screw this up.
It should be fine. We haven't seen a single Torque motor damaged by intake of dust, etc. There is a piece of FR-4 on the backside of the mounting holes which covers the back of the holes (it was originally placed there to prevent people from damaging the windings with long screws.
Patrick del Castillo
President, Principle Engineer
I like this feature, even though I always visually check screw length you can never be too careful!
Brillaint idea, IMO. I killed a Tekno Neu by not double checking my mounting screws. $105 mistake, that was
