Best al bulks for the savage?
Best al bulks for the savage? - 05.13.2009, 02:25 AM
As I am getting closer to starting the 1/5 scale savage project I was wondering which al bulks to get for it...
I have heard that the Golden Horizons bulks are nice, and retain the ez access feature that the X bulks have. I have also looked at the flm bulks, a little cheaper than the GH, but they do not have the ez access feature.
Mainly looking to use al bulks as they should keep the ring and pinion meshed better as they should not flex.
Any other info, experiences or links will as always be greatly appreciated.
Dafni
Dafni's Avatar
05.13.2009, 02:30 AM
We have very good experience with the FLM Hybrids. Never had a ringgear/pinion issue.
Maybe they are not what you're looking for (obviously no easy diff acces) just thought I share our experience.
No easy diff acces never bothered us, it's not like on a truggy where you might want to change diff oil between races... the Savage has always been more of a set-and-forget thing, diff-wise.
Daf
05.13.2009, 02:41 AM
Daf
Thanks Dafni,
Would you say the flm bulks fit together nicely? I have a set of the 1/8 diff hybrid emaxx flm bulks, and the fit leaves a little to be desired...
I can usually get the diffs setup correctly the first time, so the ez access is not a huge deal for me. Just figured I try to find out the pros and cons before I bought anything!
Dafni
Dafni's Avatar
05.13.2009, 02:47 AM
Well, considering they are FLM, you could say the have a perfect fit, if you know what mean
Seriously, they are okay. My mate had to put the dremel to a set once, to get the Flextek arms to fit perfect, but it was acceptable, IIRC.
I had the maxx hybrids as well, and may other FLM parts with an "almost" perfect fit. Know what you're talking about, but the Savage Hybrids were okay. Burrs in the hinge-pin holes and stuff like that go without saying
Electric Eel
05.13.2009, 07:32 AM
Linc. get the GH bulks. $59 at Tower.
http://www3.towerhobbies.com/cgi-bin...?&I=LXWVT3&P=7
I use these on my 1521 Flux and they hold up great. Fits the Cen diffs perfectly too.
05.13.2009, 10:03 AM
Good to know, sounds like they will compare to the emaxx bulks I have.
Ok, if they hold up to your 1521 they may work for me. Did you have any issues getting the stock parts to fit them?
