mmm v3 tips
kneedeeppow
is lovin life brushless
kneedeeppow's Avatar
mmm v3 tips - 11.14.2009, 10:42 PM
i have been running my mmm straight outta the box in my mbx5t.as fun as it is it is a real handfull on the track.i want to make use of the castle link contraption and tune it so its a little less agressive on take off.i have played with the exp on my spectrum transmitter which has helped but still i get to about 1/3 throttle and it goes nuts.any tips out there for setting up the esc via the castlelink to calm it down a bit.i still want the speed i have just not till a little later in the trigger throw
associated rc8t..........e
tamiya f104pro,r,w.f103gt.tb02,ta02
nuova faor sf501
avatar is pic of what our cat does with empty boxes left over from rc purchases
sikeston34m
sikeston34m's Avatar
11.14.2009, 10:48 PM
Go into Castlelink and work with the throttle curve.
You can set full throttle to a percentage of full throttle. Just make the curve on the right side only go to 60% or so. You may have to play with this until you see the desired results.
Also, on punch control, set it to 100%. This will help tame take off somewhat.
I hope this helps
11.14.2009, 10:57 PM
On my mbx-5T here is what I use w/good results. As sikes said, play with the settings until desired results. May take a couple of adjustments to get it to your liking
Adjusting the throttle curve is a great feature for control
brake amt. 60%
punch control 60%
low start power
lowest timing
rev. w/delay
3.2 lvc running 5s
kneedeeppow
11.14.2009, 11:02 PM
any ideas as to where the usb plugs into? do i have to lift the cover of the esc? do i need to have a battery connected?
nuova faor sf501
kneedeeppow
11.14.2009, 11:23 PM
duh,i figured it out.what a muppet now when i plug it all in,select mamba monster and get a green light saying usb status but a red light for device connection status.when i click on update or read settings a window pops up saying no contoller or invalid controller connected.
nuova faor sf501
11.14.2009, 11:27 PM
make sure all the connections, pins, are all aligned correctly or you will get a red light
kneedeeppow
11.14.2009, 11:30 PM
yip,i am a moron i had the plug upside down. green lights everywhere now.letting the fiddling begin
nuova faor sf501
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.15.2009, 12:01 AM
I use 10% punch control max for track running - anything more and the midrange starts to get muddy. I usually grab the throttle curve at 50% and drag it down to the 40% line, making for a mild curve that softens the bottom end and starts to pour on the power more aggressively after half throttle. I set brakes to 50% on the castle Link and dial any extra out on my transmitter if needed. :)
kneedeeppow
11.15.2009, 12:09 AM
cheers for the input guys.have had a bit of a fiddle with curves etc.look forward to getting the trug back out and test it out(waiting on new antenna for transmitter-old one broke now have range of about 5 feet)
nuova faor sf501
11.15.2009, 12:22 AM
Been there done that
