Vid of MMPRO creeping with 21.5 LRP
snellemin
2 KiloWatt RACER
snellemin's Avatar
Vid of MMPRO creeping with 21.5 LRP - 11.18.2009, 12:39 AM
Here's a vid of the MMpro creeping in my FLM Rustler with a 21.5 LRP stock motor w/14mm sintered rotor upgrade. Batteries were 6s1p A123.
http://www.youtube.com/watch?v=WTF1u1VNXgI
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
bigboi146
Multi Tasking
bigboi146's Avatar
11.18.2009, 12:53 AM
It seems very smooth I've been looking forward to getting one!
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.18.2009, 11:43 PM
Check out this snipped of the datalog on the setup. A whopping 6.23Amps @ 19.78V average. I'll gear up some more and datalog it again.
11.19.2009, 10:12 AM
looks nice and smooth...how did it "feel"
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2009, 10:53 AM
Man the Rustler is so "slow" and I need to gear it up some. The feel of the ESC with the sensor used is very smooth. I take a vid of it in action. Heck as it's setup up now, I can use laptop batteries and still be good with the power output.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2009, 03:58 PM
Here's the actual creeping outside my house. I changed the gearing to 58/15
http://www.youtube.com/watch?v=JDN0M1zVnwY
11.19.2009, 07:17 PM
it looks and sounds v/smooth.
sikeston34m
sikeston34m's Avatar
11.19.2009, 10:04 PM
Was there anything special you had to do during setup?
I'm trying to setup a Novak HV motor with my MM Pro, and it's acting strange.
It will only spin the motor in one direction, and if I pick two wires and swap them, it won't run in either direction.
When running in the one direction, it is very smooth. I don't think the sensors in the motor are bad or anything, but I'm not sure what I need to do.
MetalMan
MetalMan's Avatar
11.19.2009, 10:33 PM
With sensored it's vital you have the main power wires oriented with A B C matching between motor and ESC, because of the sensor orientation. If you need to reverse the motor rotation you should be able to do it from Castle Link.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2009, 10:35 PM
I didn't do anything special. I only disabled the voltage cutoff and have my timing on 10 degrees. Are you using the sensored mode only?
sikeston34m
11.19.2009, 10:36 PM
I have tried both smart sensored and sensored only mode.
I'm working with it now. I'll check the A,B,C Orientation.
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2009, 10:40 PM
Yea I forgot about the ABC's.
sikeston34m
11.19.2009, 10:47 PM
Got it!
I completely forgot about the ABC thing. Running sensorless stuff will spoil ya! LOL
This thing is amazing though. Low speed is very precise! But it will blast off like a rocket when you stab it.
Cool! Very Cool.
Thanks alot guys!
Which sensored mode is best? Anyone try cheat mode yet?
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.19.2009, 10:50 PM
I tried cheat mode a few times in a straight line. Worked good. But the onroad guys will have more use out of it.
