hi guys i dont post much on here but i get alot from reading on the forum but what im looking for is a better motor for my rustler i mainley run 3s and 2s packs any motors you recomend must be able to work with this esc http://www.rccarsandtrucks.co.uk/1962_1_2733436.html and my battery/s
How about a VXL motor? 3500kv will run fine on 2s or 3s, and should be easy to get on ebay if you want cheap. Otherwise, any motor around that same kv (or maybe higher depending on what you are using your Rusty for) like Neu 1506/1509, or similar.
